O type posi swap
Old Apr 10, 2013 | 06:22 AM
camdon454's Avatar
O type posi swap
How do I determine what gears I have in order to swap in a posi? I thought I had read that there was a code visible on the diff, or do I have to pull the cover? It's a 70 Cutlass S. Thanks for your help.
Old Apr 10, 2013 | 03:49 PM
zbarrow's Avatar
There is usually a 3 digit code stamped on the top right side axle tube in the area of the break line...Though i do not have the code break downs, if you find it and post it i'm sure someone like jim (monzaz) or brian (507olds) would be able to tell you what it means.
Ofcourse you could always pull the cover, count and divide...not a bad idea just incase the gears have been changed over the years.
Old Apr 10, 2013 | 04:58 PM
camdon454's Avatar
Thanks for the advice. The gears are original, but I agree I should have a peek anyways. I just bought the car last summer off of the original owner, and he maintained it very well. He kept all of the service record receipts and I don't recall seeing many diff fluid changes anyway!
Old Apr 10, 2013 | 06:06 PM
monzaz's Avatar
pull cover
Pull te cover- - GM already did the work for you- Read the ring gear outer diameter of the gear. Keep spinning and wiping with a rag you will find the part number and the tooth count and the year of the gear. OR post all the numbers and will figure it out for you. Jim
JD
Old Apr 11, 2013 | 08:45 AM
camdon454's Avatar
Thanks Jim. I've got a hoist rented tomorrow!
70vista
Apr 24, 2016 06:59 PM
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
jensenracing77
Jul 11, 2009 11:02 AM
monzaz
Mar 17, 2009 04:05 AM
BIGJOESX
Jun 3, 2008 02:04 PM
