O type posi options?
Old Dec 17, 2012 | 04:39 PM
kevdog442's Avatar
Member
I have an open 3.08 O type rear end. I also have a 2.78 posi O type rear end. Can I make a 3.08 posi out of these two by switching either the gears or the posi unit.
Old Mar 27, 2013 | 08:03 PM
buzzbomb's Avatar
you can use the 2:78 posi carrier up to 3:23 gears as long as they are both type O. I would replace all the bearings and races.
Old Mar 28, 2013 | 12:03 PM
pcard's Avatar
70 Cutlass SX
All references I have read indicate that the posi carrier for the 3.08 (casting 671) is not the same as for the 2.78 gears (casting 673).
Check with Jim (MONZAZ) or Brian Trick.
Old Mar 28, 2013 | 01:45 PM
507OLDS's Avatar
You will need to use a ring gear spacer to use the #673 posi unit with the 3:08 gears.I have made them before,but don't have any stocked right now.
Old Mar 28, 2013 | 05:55 PM
oldsmobiledave's Avatar
Fyi
No. This is wrong. The 2.78 carrier can be used with 2.56 gears but another carrier is needed for the 3.08 and 3.23 gears.
Old Apr 24, 2016 | 04:41 PM
anthonyP's Avatar
Do you still have the posi carrier and/or 3.08 gears?
Old Apr 24, 2016 | 05:50 PM
monzaz's Avatar
new posi unit
I have NEW O type posi units Eaton type
or a few reconditioned 8.8 ford units machined to 'o' type olds rear a little cheaper.
As Brian stated we can make you a spacer plate custom to fit the 2.56-2.78 posi unit you have to the 3.08 3.23 carrier gears.
Jim
JD
PM if interested in anything
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
Nasty455
Jul 26, 2012 04:36 AM
Jul 5, 2012 09:34 AM
monzaz
Mar 17, 2009 04:05 AM
BIGJOESX
Jun 3, 2008 02:04 PM
