o-type posi
Old May 15, 2010 | 06:08 PM
72hurst's Avatar
o-type posi
I have a 671 posi carrier and was told I could put a clutch pack from a corporate 8.5 posi. Is this true? Also could someone tell me what years the w27 option was available?
Old May 15, 2010 | 06:27 PM
svnt442's Avatar
With the O-Axle only 1970 and then it was a special aluminum centered housing that was usually replaced under warranty due to it not being strong enough to hold the abuse put through it.
Old May 18, 2010 | 06:24 AM
507OLDS's Avatar
Yes,the clutch packs from the older style 8.5" 10-bolt posi units are the same.The ones with the "S" spring like what you have.These clutches are a knurled steel,& have square tabs on the ends.The clutches for the Eaton posis will NOT work. GM discontinued the clutches last year,but there are still some sources to get them.
Old May 19, 2010 | 02:32 PM
72hurst's Avatar
o-type posi
Thanks Brian for the confirmation. Could you give me a couple of sources or do you have a set?
Old May 19, 2010 | 02:59 PM
507OLDS's Avatar
I bought a bunch from GM when there was word that they were stopping them,but I do not want to sell mine.I've talked with a few people that got them from DTS & a few other differential companies.Ratech also had them under part number RAT-1809,but I do not know if they still have them or not.Have you looked at your clutches yet.You might be able to retain your existing clutches,& just shim them tighter.They weren't assembled very aggressively back then,& usually have room for a bunch more shim.
70vista
Apr 24, 2016 06:59 PM
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
jensenracing77
Jul 11, 2009 11:02 AM
monzaz
Mar 17, 2009 04:05 AM
BIGJOESX
Jun 3, 2008 02:04 PM
