O type differential value
Old Mar 29, 2019 | 10:26 AM
eng69's Avatar
Looking for opinions on what a O type 3.90 posi rear end is worth. Complete from drum to drum and in good working order. I really don't know a lot about these units.All I really know about this one is that it's a 3.90 posi, 12 bolt cover, 10 bolts in the ring gear, and currently in a 69 GM A-body (not a Cutlass though, and not original to this car). Thanks
Old Mar 29, 2019 | 11:14 AM
My442's Avatar
No 3.90 gears unless aftermarket.
3.91 was the factory ratio.
What is the code on the axle tube on the passenger side?
Old Mar 29, 2019 | 02:18 PM
eng69's Avatar
Probably is 3.91. I was just rounding off. I'll have to get the codes this weekend and get back to you.
Old Mar 29, 2019 | 04:36 PM
eng69's Avatar
I crawled under the car tonight and looked on the front side of the axle tube and didn't find anything. I may just need to clean it better or get a better view. The only numbers I find are 402227 on the center section. Do they mean anything?
Old Mar 29, 2019 | 05:09 PM
jensenracing77's Avatar
On that rear end it should be on the back side of the passenger tube.
Old Mar 29, 2019 | 08:08 PM
monzaz's Avatar
should be a 1970 housing with oiled bearing axles You will need to find the axle tube suffix code (2 digit number letter code example : R2 SA TO T3 etc.) on the passenger back of axle tube between the coil spring perch mount and the cast center section and it will probably be stamped upside down .
Jim
J D
Old Mar 31, 2019 | 09:47 AM
eng69's Avatar
Well it's still hard to see, but I think I found it. Assuming it's upside down it looks like 73. However, it could be a T and it could be an 8. Does this make sense? I'm going to assume T3 as I thought it should be a letter and a number.
Old Mar 31, 2019 | 09:56 AM
Zachb92's Avatar
Maybe a TB? Look at this chart I found last night on this site when trying to figure out what an R2 axle is.
Old Mar 31, 2019 | 10:20 AM
eng69's Avatar
Yes, it could be a TB, but according to that chart it would be a 2.78 ratio. If so, then the guts have been changed as I know it's a 3.91 ratio in it. I had the cover off and looked at the ring/pinion tooth count, and the rpm at which I'm going 60mph all say it's 3.91. I may just have to wait until I get it out of the car and maybe strip the paint off so I can get a better look. Thanks.
Bozang1
Sep 1, 2018 02:59 PM
wyocutlass
Drivetrain/Differentials
Feb 22, 2017 05:12 PM
Napoleon1991
Sep 25, 2013 09:02 PM
MyFirstOlds
Oct 26, 2012 09:22 PM
DENT
Feb 7, 2012 09:30 AM
