o axle?
Old Mar 29, 2009 | 10:10 PM
70_CS's Avatar
torque machine
o axle?
i have a 70 type o axle do you think its posi or not it leaves two tire marks but not all the time
Old Mar 30, 2009 | 05:16 AM
Lady72nRob71's Avatar
Surest way to tell is to chock the front wheels, raise the rear of the car, release the e-brake, put shifter in neutral, and rotate one rear tire by hand. If the opposite tire turns opposite direction, then it is NOT a posi.
Old Mar 30, 2009 | 07:17 AM
Actually, the surest way is to remove the diff cover and look at the carrier. A limited slip with worn clutches can act the way you describe. Of course, there should be a metal tag under one of the cover bolts if the axle is limited slip, but these can break off or be left off if the cover was ever removed.
Old Mar 30, 2009 | 08:31 PM
70_CS's Avatar
torque machine
thanks guys i will check that i have a feeling its a lsd
Old Mar 31, 2009 | 05:02 PM
monzaz's Avatar
LSD
If you find out t=you need clutches we still sell them for the application. Just PM me. Jim
I can also offer rebuilding of that unit. I think your probably more than capable though. Jim
cutlasssupreme71
Drivetrain/Differentials
Feb 22, 2011 11:40 AM
dan1s
Sep 23, 2008 01:53 PM
dan1s
Mar 16, 2008 11:13 AM
<powers455>
Sep 13, 2007 09:11 PM
Old School
Sep 4, 2007 09:11 AM
