Need Advice, Swapping out rear axle from disc to disc.
Old Feb 28, 2010 | 02:20 AM
xerxes600rr's Avatar
Question Need Advice, Swapping out rear axle from disc to disc.
Hello everyone, i could really use some help here.
I have a 72 cutlass "s" w/ 350 rocket. it has a 2.73 open 10bolt 8.5" w/ drums. I was given a rear end taken from a 91 camaro z28 10 bolt. the cutty is 8.5 not sure of z28. It has 3.23 posi factory rear. The rear setup is w/ coil springs.
What do you think of the odd that i can do this, if it is possilbe how much work $$$ should i be expecting? I will be running disc conv for front so it will have 4 wheel disc brakes.
Old Feb 28, 2010 | 06:35 AM
70 cutlass s's Avatar
You can't do anything with it. Sell it. The rear suspension on the Camaro is different. it doesn't have upper arms like your car does. The Camaro used a long bar that runs from the rear end to the side of the transmission instead. I'm thinking the Camaro has 7.5 ring gear.
Old Feb 28, 2010 | 04:24 PM
You are correct. There is nothing that can be done with that axle in an A-body.
deflepnut2003
Sep 9, 2012 03:11 PM
NightStalker
Jan 28, 2011 06:56 AM
Aceshigh
Suspension & Handling
Apr 14, 2010 12:35 AM
jmac69cutty's
Oct 31, 2008 12:28 PM
