Measuring driveshaft length for a 4L80E
Old Dec 26, 2023 | 10:40 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I plan on converting my 70 Cutlass S to a 4L80E. What is the correct way to measure? It is the suspension fully extended correct? Does anybody have the actual length needed with the 12 bolt O axle along with needed U joints? I know the yoke needs to be the TH400/4L80E 32 spline yoke. I will need a whole different driveshaft, my current is the factory TH350 with the rubber connector holding the two pieces together.
Old Dec 26, 2023 | 02:44 PM
You want to measure with weight on the wheels. The yoke needs to have 3/4 of an inch freeplay and measure center to center of the ujoint cup holes between the yoke and the rear diff.
Old Dec 26, 2023 | 03:31 PM
gs72's Avatar
72Cutlass S
We had one made for my son’s 64 C10 pickup. Called the drive shaft shop. They wanted the measurement from the center of the rear u-joint (which is the strap mounting surface of the yoke) to the end of the trans tail shaft housing. Turned out perfect. Call your driveline shop, they will walk you through it.
Old Dec 26, 2023 | 04:13 PM
Thanks makes sense to follow their lead on measurements.
Old Dec 26, 2023 | 04:24 PM
Loaded68W34's Avatar
If you are looking for a shop, I have had two made from by PST. They have a quick turn around and are helpful on the phone.
https://pstds.com/
I think the turn around time was about a week from the time I called until the shaft was shipped. Both were 4" aluminum shafts built from yoke to yoke. They supplied the trans and rear diff yokes and my measurments were seal to seal. Whatever supplier you use, be sure to discuss critical speed and shaft diameter/ material with them.
Here is the driveshaft they made for my Vista.
Old Dec 26, 2023 | 05:25 PM
Yeah I want something strong that won't rattle out my teeth.
Old Dec 27, 2023 | 11:19 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Dennys Driveshafts
See the measurement sheet
https://www.dennysdriveshaft.com
tkw31
Jun 17, 2024 02:30 PM
tkcutlass
Drivetrain/Differentials
Mar 19, 2022 08:35 PM
Fun71
Jan 24, 2017 12:27 PM
Oldsragger
Apr 14, 2015 04:19 AM
dfire25
Sep 24, 2013 08:02 PM
