Me again, dripping tranny fluid
Okay so 3 weeks ago I drove the car, let it sit in my driveway for 4 hours before pulling it into my garage, not a drip, never has leaked any fluids.
Tonight I just happen to drop a bolt and look under the car to see a puddle of tranny fluid under the car. Looked a little harder and se a pretty steady drip coming from the u-joint, nothing else is wet. The tranny isn't even pointed downwards to have fluid to that low point.
Any thoughts? Thanks!
Again, I ran my hand over everything forward of the leak and couldn't find a thing. I have a pan under it now so obvioulsy I know its the tranny if it starts filling up.
They can dry out or wear out. If the car(tranny) has been sitting for a while the rubber can dry out. If the car(tranny) is often used metal rubbing rubber will eventually wear the seal out. Its not to hard to replace. Unbolt the drive shaft from the rear end and slide it and the yoke out the back of the transmission. Pull the seal out, pop in a new one, slide the yoke back into the transmission and bolt the other end back up to the rear end. Done!
Looks to me like the entire yoke is wet and your problem is the rear seal. No matter what, you'll need to pull out the yoke to see what you . Even if there is an O ring in there, I would change the rear seal anyway.
Hey Darrel, yeah it does look wet but not wet enough to have been dripping as fast as it was, I am assuming it's still leaking but haven't checked since yesterday. Look at the edge of the seal it's not wet at all. Just seemed odd to me the way it was dripping, the tranny is not at an angle either.
Anyway, I agree with you it needs to be pulled either way to find out what's going on there. Thanks for your input I do appreciate it.
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
