Installing new Axles
Old Mar 5, 2019 | 06:05 PM
rick442's Avatar
Hello All,
This is my first experience installing. Am I supposed to tap this in? The retainer plate is about a 1/4" from the axle plate.
I just want to make sure.
Old Mar 6, 2019 | 08:18 AM
I have always tightened the bolts/retaining plate to push the seal into the end of the axle shaft.
Old Mar 6, 2019 | 10:04 AM
rick442's Avatar
Thanks Kenneth! Monzaz helped me as well. They pulled in.
Old Mar 7, 2019 | 04:03 PM
monzaz's Avatar
spacer plate
You need the spacer plate between the flange and the retain plate ...it acts as the backing plate thickness...They come in most disc brake kit and are for the bolt in axle rears BOP usually.
I have extra plates here if you need as they come in c-clip disc brake kits so I just save them.
YOU MUST have this spacer plate in or you will ruin the seals.
Tims68Olds
Brakes/Hydraulic Systems
Mar 11, 2020 09:32 AM
Natedawg
Drivetrain/Differentials
Jun 17, 2019 05:22 PM
Moses
Jun 11, 2011 12:58 AM
Moses
Jun 10, 2011 09:37 AM
oldzy
Mar 3, 2011 07:15 PM
