help,,,runout bolt,,,prop shaft position
Old Aug 25, 2010 | 11:27 PM
1973olds98's Avatar
I replaced the differential seal on my car,,,I got it all done and drive shaft back in and i was reading my shop manual and it stated before bolting prop flange to differential flange check for run out bolt,If it has a runout bolt instal prop flange straddling the runout bolt,,if no runout bolt is present install prop shaft in any position,,After getting under my car i seen mine does have a runout bolt,,,What does straddling the runout bolt mean...How do i know if it is in the righ position..,
Old Aug 29, 2010 | 07:23 PM
monzaz's Avatar
Run out bolt
It just mean do not install the companion flange in a position that the run out bolt will be in the way. Kind of idiot info as the run out bolt would NEVER let the flange bolt flush. Jim
Get me a picture and I will try to modify the pic to show you. Jim
Lars
Wheels and Tires
33
Mar 27, 2013 09:54 PM
Frogge467
Mar 24, 2012 11:09 PM
72442conv
Mar 19, 2012 07:14 AM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
joe_padavano
Brakes/Hydraulic Systems
Jul 1, 2009 10:10 AM
