HELP with C-clip eliminator kit
Old Jun 13, 2012 | 04:47 PM
ATrain1's Avatar
I received my Moser axles and Moser C-clip eliminator kit today for my GM 7.5 rear end today and I have a problem. It seems like the C-clip eliminators slide all of the way down the axle with kind of a loose fit, I do not see any way it can be pressed on. Now am I missing something? Has anyone else had this problem? I called Summit and they said that the kit an d axles should work with each other. Thanks for your help.
Old Jun 13, 2012 | 05:50 PM
Rickman48's Avatar
About 2" from the axle flange there should be a machined surface the bearing rides on - that's the press-fit area.
If the bearing slides over that, they sent the wrong bearings!
Old Jun 13, 2012 | 07:55 PM
ATrain1's Avatar
Yeah it slides all the way down.
Old Jun 14, 2012 | 04:34 AM
507OLDS's Avatar
It's the wrong c-clip eliminator kit for that axle shaft.Even if it was an 8.5" 10-bolt G-body axle,it still isn't the correct eliminator kit.The 7.5" and the 8.5" both use the same 5707 bearing & 8660S seal combination on their c-clip axles.The eliminator bearing needs to be able to press onto the bearing surface of the axle,along with the lock ring.
Old Jun 15, 2012 | 07:01 AM
ATrain1's Avatar
Yeah I measured it and the bearing surface is 1.399 on the axle, and the C-clip eliminator bearings measure 1.533 which would explain my problem. Will I need to run a longer axle? Thanks for your help.
Old Jun 15, 2012 | 11:13 AM
507OLDS's Avatar
No,you do not need a longer axle for c-clip eliminators.The ends of the housing,where your regular bearing would be,needs to be cut off.The backing plate flange remains on the housing,to bolt the eliminators to.
garys 68&72
Drivetrain/Differentials
Mar 31, 2015 04:49 AM
yankees
Feb 3, 2015 04:36 PM
delta254
Dec 22, 2012 11:39 AM
HIGHCOMP425
Dec 20, 2011 07:19 PM
#1CutlassSupreme
Sep 24, 2009 02:43 PM
