Gear ratio help
Old Oct 2, 2019 | 01:34 PM
Reese Neis's Avatar
Gear ratio help
I’ve got a 1970 cutlass supreme with a 455 with 600 hp and a th400 trans I was wanting to know would I be able to run 3.42 gears and not be screaming down the highway doing 75 and what would the stock gear ratio be
Old Oct 2, 2019 | 02:15 PM
deadeyejedi's Avatar
There will be some more qualified than i on this subject ,but the short answer is no.The reason i say this is because i have a 455 w/turbo 400 and 3:23 gears and going down the highway at 63 mph im turning 3000 rpms. Also i still have the 14 inch tires ,15in tires will help .Theres a good chance the stock rear was 2:73 . There are online calculators that will give you a good idea where you'll be at. For example, if you have 27 inch tall tires you'll be at about 3000 rpms at 70mph you current gears
Old Oct 2, 2019 | 02:31 PM
69CSHC's Avatar
Top performance gear option for a 1970 Cutlass Supreme Holiday Coupe 455 CID, THM 400 was 3.42
At 75 mph the engine will be turning about 3500 rpm with a 26 inch tall tire.
Your engine should be fine, although its gonna sound like its working hard. Nature of the beast back then.
https://www.automobile-catalog.com/auta_details1.php
http://www.wallaceracing.com/calc-gear-tire-rpm-mph.php
Old Oct 2, 2019 | 02:37 PM
Tuffnut's Avatar
I currently have 3:42 gears with an 200-4R OD... I did the switch to OD because of the revs on the highway cruising at 70-75 mph with my old th350 tranny with 15" tires. I love the gears, sure woke the car up....
Old Oct 2, 2019 | 03:46 PM
69CSHC's Avatar
2.56 was stock base standard gear on 1970 Cutlass Supreme H C with 455
G78-14 was standard tire for this model.
All possible ratios were as follows 2.56 2.78 3.08 3.23 3.42
PS so cool that 455 was a factory option for your car, not the case for 1969.
Old Oct 3, 2019 | 03:33 PM
11971four4two's Avatar
MOTORHEAD
342 is a nice all around ratio
Put on some short / race tires
Go to the track and have FUN
tgilligan
Drivetrain/Differentials
Oct 7, 2019 06:29 AM
Asbussey
Apr 14, 2018 07:17 AM
Olds luvr
Apr 8, 2015 03:53 PM
72CUTTY
May 16, 2012 05:11 AM
Newkid8
Mar 11, 2008 07:52 PM
