g force crossmember
Old Apr 11, 2018 | 10:40 AM
oldsdriver1218's Avatar
Question g force crossmember
has anyone used one of these g force crossmembers on a cutlass they look well built just wondering if anyone has installed one and how it turned out mine is a 1971 cutlass convertible any input will be appreciated
Old Apr 11, 2018 | 11:14 AM
csouth's Avatar
I have one on my car that was originally purchased when I was going to do a 4L80E swap. I was able to use it for my T56 without any problems. They are very well made. Keep in mind I have a hardtop so my frame is different, but still no issues.
Old Apr 11, 2018 | 12:33 PM
thanks any information helps when thinking of buying one
Old Apr 11, 2018 | 01:36 PM
Run to Rund's Avatar
If you are not changing to some other type transmission, the stock crossmember, either the stamped or tubular (lighter weight), is fine.
Old Apr 11, 2018 | 05:25 PM
In fact, if you have a hardtop open channel frame, why spend a dime on an aftermarket crossmember? Simply slide the original to where the new trans requires it to be and drill holes as needed.
Old Apr 12, 2018 | 06:02 AM
that would be great but as you can see in my little picture its a convertible witch has a boxed frame but thanks
Old Apr 12, 2018 | 08:30 AM
TripDeuces's Avatar
Since I have a 66 Cutlass convertible I plan to use a TH400 in I bought a G-Force cross member. The thing is built like a tank, maybe even overkill. The square and rectangle tubing is standard wall thickness stuff, .100-.125 but the exhaust pass through humps are formed 1/2 inch plate and the end plates that bolt to the frame are 3/8 inch plate. Can't complain about the quality or workmanship.
Old Apr 12, 2018 | 10:16 AM
thanks it looks like its built to last glad someone who has one replyed
Old Apr 12, 2018 | 04:25 PM
Mr Nick's Avatar
I would contact G-Force and confirm it will work with your convertible frame.
Old Apr 13, 2018 | 11:30 AM
csouth's Avatar
They make a crossmember for convertible frames....
speedaddict78
Dec 14, 2013 01:46 PM
9drsixwheelolds
Nov 1, 2010 09:15 AM
z11375ss
Jul 24, 2007 10:31 AM
help442onguam
Mar 5, 2007 12:10 PM
