Driveshaft specifications
Old Oct 4, 2012 | 11:33 PM
Nufo's Avatar
Question Driveshaft specifications
Need some guidance. I have searched on WAC and searched on CO and can't find the info I need. I have a '66 442 4speed that I have been restoring. I am looking for specifications for the proper driveshaft. The only spec I know is that the length from centerline to centerline on front/rear U-joints
should be 60". What I would like is the following:
1) Diameter of driveshaft tube
2) Make/model of correct rear U-joint - if multiple org. suppliers please list
3) Make/model of correct front U-joint - if multiple org. suppliers please list
4) Make/model of front yoke - if multiple org. suppliers please list
With this information, I can then determine if I currently have the correct
driveshaft for my car. I suspect that I don't, but I need this info to verify
whether or not my suspicion is correct.
Thank you,
Nufo (Fred)
Old Oct 5, 2012 | 05:10 PM
Nufo's Avatar
hopefully somebody has the knowledge I'm seeking and will share....
Thanks,
Nufo (Fred)
Old Oct 6, 2012 | 09:31 AM
Nufo's Avatar
Driveshaft/U-Joint Specs
any '66 442 guys out there know the answer? Joe P. ???
Old Oct 6, 2012 | 10:33 AM
What makes you think the drive shaft you have will not work? I had one fabricated for my car for about $275. Gave them the measurements and the front yoke, in 2 days I had a driveshaft.
Old Oct 6, 2012 | 10:51 AM
Fred, only thing I can suggest to you is based on my observations tearing down and redoing my drive shaft on my 72.
2,3,4 - if it's OEM will likely all be Saginaw.
Maybe someone with a 66/67 could caliper them for you. Don't know if your driveshaft is like mine but the OD on the spline end is different than the yoke end.
Old Oct 6, 2012 | 01:49 PM
Nufo's Avatar
Oldcutlass - The driveshaft I have is not the original to the car. The pinion yoke on my car takes a different diameter cup on the U-Joint then what this driveshaft that I got uses. I'm trying to determine if the driveshaft I have is correct for my car, or if it's out of a Chevy or some other GM product. The only things I know for sure are these:
1) the transmission is original
2) the rear end including pinion yoke is original
3) the correct driveshaft length is 60"
I'm trying to determine if the driveshaft I bought is correct. In order to
make it work, I have to use a rear U-joint that has a longer "Y" axis then
the "X" axis. I don't recall that being the case on my car originally but I'm
not sure. I'm trying to ascertain what U-Joints Olds used with the '66 442
with 4-speed transmission. Yes I can have a driveshaft made to fit my car,
that is not the purpose of my post. The purpose is to get enough info to
know whether or not I have the correct driveshaft.
Allen R - Thank you for your response and like you said I'll give it a little
time and see if a '66-'67 442 guy jumps in here...
Thanks,
Nufo (Fred)
Old Oct 7, 2012 | 06:44 AM
I see, hopefully someone can chime in and help you with that. As you know my application is not stock nor a 4 speed.
Old Oct 7, 2012 | 10:27 AM
Nufo's Avatar
I used a conversion u-joint for now but I don't think this driveshaft is correct... will wait until somebody that is familiar with '66 442 4-speed cars finds this thread and has the urge to share....
Old Oct 7, 2012 | 10:53 AM
wmachine's Avatar
Trying to remember member
I can tell you this: If it is two-piece shaft, it is not correct. The auto versions are two-piece, and the manuals are one piece.
Old Oct 7, 2012 | 11:34 AM
Nufo's Avatar
it's a one piece...
Old Oct 7, 2012 | 03:56 PM
Nufo's Avatar
pics of the players
thought I would post some pics of the pieces I'm working with. Might help somebody see what I have and what is correct/wrong..
Old Oct 7, 2012 | 04:19 PM
Right, wrong, or indifferent, that drive shaft looks to be up to the job. Everything looks to fit well. I'd use it.
Btw, it sure looks purty under there!
Prsabordo
Mar 3, 2010 02:38 PM
oldsmerc
Sep 23, 2009 10:09 PM
FATRATMATT
Apr 11, 2009 05:06 AM
442 Guatemala
Feb 19, 2009 07:20 PM
scott_442
Sep 10, 2008 10:59 PM
