need some advice
need some advice
hello everyone, i have a question for you. i just recently puchesed some olds rims for my 75 cutlass supreme and they only fit the front of my car. the rims have a bolt pattern of 4"5/8s, and my rear end has a bolt pattern of 4" 3/4s. what can i do to get these rims to fit? my rear end is a 12 bolt, posi, with 3.08 rear gears, and from what i was told it came out of a 68 olds delta 88. any help would be greatly appreciated. thanks
A '60s through '70s A-body will have a 4¾" bolt pattern.
A '60s through '70s B-body will have a 5" bolt pattern
(except for the '77-'84 non-diesel, non-wagon Deltas).
This is one of the reasons to use caution when swapping parts between model series.
There are two possible ways to use your wheels on that car:
The short answer is that you can't do it without a bunch of extra work.
- Change the axle shafts.
I have no idea how easy or hard it would be to find shafts that length with the smaller bolt pattern, but I would imagine you could have them made up if worst came to worst.
"Monzaz" on this forum would be able to tell you. - Use adapters.
This is not recommended, as it is not entirely safe, and it will space the wheels outboard, which you may not be able to afford, as you already have a full-size rear under there.
The easiest thing to do would be to take your existing rear axle shafts and brake drums to a machine shop and have them drilled for the smaller pattern. Get the shop to install new wheel studs for you while they are at it.
Brian
Brian
Brian
In any case, EVERY Cutlass (and GM A/G body) built between 1964 and 1988 model years uses a 4 3/4" bolt circle, and every one of them had the same pattern at both ends of the car. If yours are different, someone swapped the axle.
jpaulwhite
Mar 4, 2011 04:14 AM
eddieunderground
Brakes/Hydraulic Systems
Jan 12, 2011 06:32 PM
