Drive shaft problem
Old Apr 6, 2016 | 07:05 AM
Xlhowie's Avatar
Drive shaft problem
I purchased a drive shaft from someone on this forum for my 68 Cutlass S and the U joint are bigger than the one on the trans and rear end.
Need help getting the proper driveshaft.
Thx, Howie
Old Apr 6, 2016 | 07:07 AM
Are you sure you just don't need the correct ujoint?
Old Apr 6, 2016 | 07:09 AM
Might it not be easier to use a couple of "adapter" U-joints?
edit - I think Eric and I have the same idea.
Old Apr 6, 2016 | 07:11 AM
Xlhowie's Avatar
The rear end joint is the small one and the knuckle on the Turbo 350 is a small one but the one welded to the driveshaft and the new u joints I have are nearly 1/4" bigger. I am going with the driveshaft I guess.
Old Apr 6, 2016 | 07:18 AM
Xlhowie's Avatar
Adapter U-Joint?
What are they, never heard of them. Thx, Howie
Old Apr 6, 2016 | 08:06 AM
Indy_68_S's Avatar
Aka 'conversion' U joints.
The joints have two different cap diameters and sometimes widths. One pair sized for your yoke and one pair sized for your driveshaft. Used when swapping yokes/shafts from different makes.
http://www.supercarsunlimited.com/Ol...nt.-d1874.aspx
(but no pics)
Sample pic
Of course, first you need to know what your shaft and yoke info is.
Frogge467
Mar 24, 2012 11:09 PM
egknz
Drivetrain/Differentials
May 15, 2011 07:30 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
rose
Feb 24, 2009 10:42 AM
68conv455
Apr 11, 2008 11:48 PM
