Drive shaft
Old Jun 7, 2018 | 06:44 PM
2oldsguy's Avatar
Drive shaft
While I am waiting for my new aluminum heads for my 70 442 455 4spd., I am diagnosing a drivetrian vibration. The first thing I noticed is the trans yoke is sticking out 1 3/4". Is this too much?
I also checked the driveshaft angles and the trans is 4 degrees down and the pinion is 1 degree up. The front of the rear is pointing down, which should be down angle, but Spicer is calling it up angle. I know they should be equal so it looks as if I have to raise the trans quite a bit. Anyone havfe experience with this?
Joe
Old Jun 8, 2018 | 06:03 AM
Was this originally a 4spd car or was it converted from a TH400?
In any case, the right thing to check is to unbolt the driveshaft from the rear, push the trans yoke all the way in, and pull it out 0.75" to 1". That's where it should be. If the driveshaft is too short, it might be a TH400 shaft.
Old Jun 8, 2018 | 06:45 AM
Run to Rund's Avatar
The diff rotates under power, so the pinion should point down slightly when at rest. The yoke should be out about 1.25" from being fully inserted into the trans.
Old Jun 8, 2018 | 07:34 PM
2oldsguy's Avatar
Thanks for the response.
I do not know if it was converted from a TH400 or not, anything is possible with this car. I purchased the car from a widow in 2005.
I looked the shaft up in my interchange manual and it states I should have a 56" shaft, the one in the car is a 55".
I did state the pinion is pointed down 1 degree, but Spicer's web site calls that "up angle".
I did a runout on the shaft at the rear and it is .055", so I am looking for the correct shaft.
I like to talk to the guy who worked on this car before I got it because he should not be working on cars.
Joe
Old Jun 9, 2018 | 08:50 AM
Kennybill's Avatar
Hopefully it'll be decades before you can talk to him if you bought it off a "widow."
Old Jun 12, 2018 | 02:16 PM
2oldsguy's Avatar
I purchased the car from the wife of the last owner after he passed away. He only owned the car for 9 months.
The guy I am talking about is the person who sold HIM the car.
Joe
Old Jun 12, 2018 | 05:04 PM
tru-blue 442's Avatar
Old School Olds
I have this one piece unit pulled from a 72 4 speed car. Still has it's original U-joints in it. It shows to be 56 1/2" or a tad longer. PM me if interested.
Old Jun 12, 2018 | 06:44 PM
Gary M's Avatar
My 72 cutlass 455 with turbo 400 drive shaft is 55 3/4. Not that it's exactly correct but have no issues, for comparison. Measured mine just like tru-blu 442
83hurstguy
Drivetrain/Differentials
Jan 3, 2018 05:22 AM
Uncle Hulka
Apr 17, 2016 05:13 PM
Robert Kiedrowski
Jun 28, 2015 05:22 AM
66-3X2 442
Jul 22, 2011 07:50 PM
Schober Motorsports
Oct 20, 2009 07:08 PM
