Differential 10 bolt gasket?
Old Oct 26, 2013 | 07:07 AM
Harmon's Avatar
Went to advanced and they showed 11 or 13 bolt pattern gaskets. I assumed rear end was always in car but maybe not? My car is a 1980 oldsmobile cutlass supreme that came with the 260 CID. Thanks for any insight.
Harmon's Avatar
My rear end has a 10 bolt cover
Old Oct 26, 2013 | 07:32 AM
don71's Avatar
same but different
You should be able to find a gasket for that. But you don't have to use a gasket. You could use RTV, permatex gasket maker etc.
Old Oct 26, 2013 | 08:06 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Your rear end should be a 7.5".
Tell the dummy at the parts counter, the gasket is Part No. RDS 55072
Old Oct 27, 2013 | 07:33 AM
Harmon's Avatar
Thanks for the help y'all...it's 2.23 rear end that came in car as I have the build sheet
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
65Delta88
Drivetrain/Differentials
Sep 24, 2008 06:46 PM
Sixoh
Aug 8, 2006 05:11 AM
