Different length U-bolts
Old Jan 2, 2014 | 07:52 AM
msarver's Avatar
Does anyone have any information on the different length u-bolts for the rear u-joint. I am having difficulty finding a u=bolt that is long enough to go through the yoke. I received a pair from Yearone that have the correct width but they are .25 to .50 short. Any help would be appreciated!
The car is a 69 442 convertible 4 speed manual tranny
Mike
Old Jan 3, 2014 | 06:32 AM
msarver's Avatar
This is a surprise? Nobody else ever have this issue or see the difference? I'm pretty new to this so am I missing something? Feel free to call me an idiot, I will not be offended. I'm just looking for a resolution to get a part
Old Jan 3, 2014 | 11:42 AM
m371961's Avatar
Are you sure u-joint is seated in yoke?
Old Jan 3, 2014 | 11:56 AM
msarver's Avatar
Yes the Joint was seated correctly
Old Jan 6, 2014 | 11:27 AM
msarver's Avatar
Yes the u-joint is seated correctly.
Old Jan 6, 2014 | 12:57 PM
don71's Avatar
same but different
I ran into this problem too. I couldn't find long enough bolts at any of the auto parts stores in town. I installed a 69 diff. in my 71 using the 71 driveshaft. This has been five or six years ago but I did get the right bolts from 507olds. It had something to do with the yoke and maybe u joint combo? I know our cars are not exactly the same but, hopefully these photos will help.
Old Jan 6, 2014 | 01:52 PM
msarver's Avatar
Mine would be the u-bolt type so hopefully 507Olds can come up with another set. Thanks for your inpot!
Old Jan 6, 2014 | 04:16 PM
1001coins's Avatar
I had the same problem I went to a shop that just does rearends and gave them a short one said I needed longer gave me a used longer set for $5 worked perfect
Old Jan 6, 2014 | 05:23 PM
msarver's Avatar
I tried the same thing and the shop I went to wasn't as helpful. The only information they offered was the u-bolts are all standard lengths and they wouldn't have anything.
Old Jan 7, 2014 | 02:56 AM
507OLDS's Avatar
I will get a pair for you. I have used ones. I also kept a HELP package from when I bought a new set,as I had to do some research when I was at the parts store. I have the HELP number.Might be Dorman.
Old Jan 7, 2014 | 04:56 AM
msarver's Avatar
Used are fine with me. Thank you Brian
I'm not sure what you mean by a HELP package?
Old Jan 7, 2014 | 05:24 AM
R-body_mopar's Avatar
Exclamation
"HELP" is a registered trademark brand of hard to find parts, usually carried by larger auto parts stores; you might try a local store, or try here:
http://www.oreillyauto.com/site/c/br...lp!(TM)&mc=MTM
If 507OLDS has the Dorman number, you should be able to order some from your local parts store!
Old Jan 7, 2014 | 06:04 AM
msarver's Avatar
That would work for me. The diameter I need is 1-1/8
Brian, Either way works for me- if you have a used set or the Dorman PN
Old Jan 7, 2014 | 07:17 AM
monzaz's Avatar
u bolts
I have been keeping USED ones also. ALL the NEW aftermarket parts are ALL over the place with length. It is truly incredible the crap that is out there. The way of the future for all products. No one gives a hoot what is out there UNTIL they need the right part of course and it personally affect them. Jim
I have gone to parts stores and had them pull all the u-bolts off the shelf that fit the application and did side by side tests and they could not believe they were all slightly different from u-bolt to u-bolt and manufacture. SO I can only tell you pull as many as you can at one store and take the best ones you can find. Jim
Old Jan 7, 2014 | 07:26 AM
msarver's Avatar
There are 3 Dorman U-bolt kits-
8002
Application Summary: Buick 1980-75, Chevrolet 1986-53, GMC 1986-73, Oldsmobile 1980-75, Pontiac 1980-75, Pontiac 1970
8004
Application Summary: Ford 2006-65, Mercury 1980-65
8008
Application Summary: Jeep 1980-62
Old Jan 7, 2014 | 08:31 PM
507OLDS's Avatar
None of those numbers.The correct number is 81002. I believe I had to order these last time,but they match the originals perfectly.
Old Jan 8, 2014 | 05:01 AM
msarver's Avatar
Oh man- all the numbers should be 8100* not just 800*
Old Jan 9, 2014 | 02:45 PM
msarver's Avatar
Went to the local Fisher parts store and they were able to get the Dorman 81002 u-bolts. Brought them back and whala! perfect fit! Thank you all for your input!
vmathy
Jun 29, 2015 07:01 PM
Sampson
Dec 28, 2014 07:41 AM
nolabigdawg
Oct 25, 2014 11:50 AM
Tom442
Jan 23, 2014 07:22 PM
Oldssupreme
Feb 6, 2013 12:39 AM
