different blocks for stick or automatic tranny
Old May 18, 2009 | 08:33 AM
olds4life's Avatar
hey olds nation!!! i have a question. can i used an 70 455 that came as an automatic and hook a 3 or 4 speed tranny to it. if not what will i need to do. or is it better to get a block that was hook to a stick. thanks
Old May 18, 2009 | 08:56 AM
MN71W30's Avatar
As far as I know you'll have to pull the crank and have it drilled. I was able to do it without pulling a head by using a hoist and an adjustable engine puller attachment with a crank on it. The crankshaft needs to spin in just right with delicate control of the procedure. You may want to pull a head to do it. Good luck finding an Olds stick motor.
Old May 18, 2009 | 10:53 AM
Eric Anderson's Avatar
You can also use an adapter like the one on this site: http://dickmillerracing.com/store/page14.html
Old May 18, 2009 | 11:09 AM
The prior posts have discussed the issues with the AT vs. MT crankshafts, but back to the original question. The BLOCK was the same. Just be aware that some blocks cast after the early 1970s may not have the threaded hole for the pivot ball for the clutch linkage cross shaft (AKA, the Z-bar).
Old May 18, 2009 | 04:14 PM
My442's Avatar
Thumbs down
I did a 100% factory conversion on my 70 442. Used every single GM part, except for the pilot bearing.
I used one of the adapter bearings, after drilling out the crank for input shaft clearance.
Drilling the crank is harder than a wedding dick.......no lie, it is a BITCH.
Anyway, after the conversion, the tranny was hard to shift into reverse.
After about 500 miles, the conversion bearing spun in the ID of the crank.
So I pulled the engine, and brought the crank to my machine shop. Come to find out that the recess in the auto tranny crank was off center to the crank center line. That made the input shaft spin when the tranny was in neutral.
I had the crank drilled out using the specs in the Mondello Tech Manual, and used a BCA7109 bearing.
Works great now.
So, I don't recommend the conversion bearing.
Drilling the crank for the BCA7109 bearing was $150. The bearing is about $20.
Old May 18, 2009 | 08:02 PM
MN71W30's Avatar
Works great now.
This information is priceless. Thanks for the heads up on those bearings.
Old May 19, 2009 | 03:43 AM
...Come to find out that the recess in the auto tranny crank was off center to the crank center line. That made the input shaft spin when the tranny was in neutral.
Wow. Sorry to hear that. I know it's no consolation, but your experience is the exception, not the norm. Of course, that's been the story of my life too...
Old May 19, 2009 | 07:48 AM
olds4life's Avatar
thanks fella's. drilling the crank is way above my mechanical abilities. i may just put a 350 in my 442 until i can find manual engine/tranny combo to put in it. thanks again.
Old Jun 13, 2009 | 07:54 AM
Warhead's Avatar
I have a stickshift crank, AND an M-20 for in front of it.
Some assembly required.
JIm
Old Oct 24, 2009 | 06:23 PM
gmrocket's Avatar
Membership Revoked by Admin
you missed the post above about the conversion bearing that doesnt require drilling of the crank. it works
navvet
Jun 8, 2014 07:21 PM
RAMBOW
Jul 29, 2013 05:32 PM
rgorewit
Jun 28, 2013 06:37 AM
Adrian Lawrence
Nov 16, 2010 10:14 AM
ZASX
Nov 19, 2007 04:34 PM
