Custom Cruiser 8.5 rear questions
Old Nov 18, 2024 | 01:15 PM
The Stickman's Avatar
Ok I just recently bought a 1984 Olds Custom Cruiser and there is a clunking in what I think is the rear when I let off the brake. Today I got the car up on jack stands and if the car is in neutral and a spin one wheel by hand the other does not spin at all. If in park and I spin one wheel the other spins backwards. Shouldn't the wheels not spin at all in park? And if in neutral both wheels spin if I spin one? Is this rear on it's way out?
Old Nov 18, 2024 | 06:35 PM
The behavior you describe is normal for a non-posi axle. And you might want to double check the axle. My 84 Custom Cruiser came with an 8.75" Type P axle.
Old Nov 18, 2024 | 06:38 PM
Good to know. I always thought when you spun a tire in neutral the other would spin in one direction or the other.
Old Nov 18, 2024 | 06:48 PM
On a non-posi axle there are three shafts to spin (driveshaft and the two axles). If all three are unconstrained, only the two with the lowest friction will turn. In neutral, one of the brakes is dragging more than the driveshaft. In park, since the driveshaft can't move, the wheels turn in opposite directions. If you completely backed off the brakes and tried it in neutral, both wheels MIGHT turn instead of the driveshaft, depending on the friction in the trans.
Old Nov 18, 2024 | 07:01 PM
I didn't consider one of the brakes might be dragging. Honestly I was more concerned with the clunking I hear during driving, and the hole in the floor pan I now have to fix that I thought was two small holes.
Old Nov 18, 2024 | 07:07 PM
lshlsh2's Avatar
71 cutlass convertible
You might want to check your u joints also. When worn out they can make a clunk.
Old Nov 18, 2024 | 07:16 PM
Yea I checked and those are fine. Honestly the car is fairly clean. Which makes that rust spot really weird. The floors are really clean except for that spot on the rear driver side.
olds1966
Drivetrain/Differentials
Feb 3, 2025 07:29 AM
smparr
Jun 21, 2022 01:15 PM
philjr
Aug 15, 2016 11:56 AM
rustyroger
Apr 14, 2013 11:59 AM
lmanc2222
Vista Cruiser & Wagons
Apr 3, 2010 08:46 PM
