crooked rear
Old Jul 19, 2022 | 04:05 PM
70-455's Avatar
crooked rear
I`ve noticed my 12 bolt rear is crooked.Is there any alignment dimensions either from center of brake drum to back or front of wheel lip molding?I took measurments and came up about 2inch difference from driver to passenger side.Also what would cause that?All bolt holes line up.
Old Jul 19, 2022 | 04:20 PM
Model/Year would help.
Here's a link to a 1970 (probably good through 1972). You might reach out to Tom (who posted) asking if he has other dimension diagrams if this is not applicable to your vehicle.
https://classicoldsmobile.com/forums...-frame-146230/
Old Jul 19, 2022 | 04:23 PM
This may work better...
Old Jul 19, 2022 | 04:36 PM
66_Jetstar's Avatar
Measure wheel center to center on both sides and go from there.
Old Jul 19, 2022 | 04:49 PM
70-455's Avatar
Rear
The car had a incorrect 10 bolt when i bought it.Put the 12-bolt olds in and notice it wasn`t driving wright.Then notice the twist.
Old Jul 19, 2022 | 05:10 PM
The fender openings are not the controlled dimensions. What matters is how the axle is aligned relative to the chassis.
Old Jul 19, 2022 | 06:54 PM
Did the car drive OK with the 10 bolt rearend?
Was the O-Type installed with control arms attached, or were the existing control arms reused?
Old Jul 19, 2022 | 07:24 PM
Chances are it's not the differential that's out of alignment. It's the frame to body alignment that is off.
Old Jul 20, 2022 | 09:24 AM
70-455's Avatar
Rear
I`ll have to measure the wheel crnters first,like 66 jetstar suggested.
maniehau
May 6, 2022 05:04 AM
CANADIANOLDS
Oct 6, 2021 07:35 PM
Bee Saint Louis
Dec 11, 2016 07:44 PM
Joffroi
Brakes/Hydraulic Systems
Jan 17, 2011 02:02 PM
thislilpiggy
Nov 1, 2009 11:18 AM
