cheap gears, where can i get some?
Old Apr 12, 2007 | 01:14 AM
shaks 442 clone's Avatar
i have a 12 bolt olds rearend im in the process of taking it down to bare metal and painting it but before that i want to upgrade the 2.73 gears in there at the moment
i cant seem to find gears maybe im not looking the right way all i can find are complete ready to go diffs can anyone help me with some links?
im looking in the range of 3.55's
would that work good with a th350??
or would i be red lining at like 80mph?
Old Apr 12, 2007 | 04:39 AM
Oldsguy's Avatar
Past Administrator
Do a search on this subject. I think I remember a post back in December maybe that discussed this. The Olds 12 bolt is very difficult to get diffferent parts for. If I remember correctly, somoene mentioned that this tranny was only used for a few years before Olds started using either the 10 bolt or the corporate 12 bolt. I can't remember all the specifics but like I said, use the search, I am sure it is there.
Old Apr 12, 2007 | 06:56 AM
Which "12 bolt" axle do you have? 442s could have come with either the traditional Chevy 12 bolt or the Type O. The Chevy axle was mainly used in cars built in Canada and can be identified by an upsidedown "V" stamped into the back cover. This axle used C-clips to retain the shafts and an 8.875" ring gear held on by 12 bolts.
The Type O has a smooth rear cover and the axle shafts are retained at the outboard bearings. The bad news is that this "12 bolt" is actually only a 10 bolt since the 8.5" ring gear is held to the carrier with 10 bolts. These axles were only used in 67-70 Cutlii and parts can be hard to get. There are no "cheap" gears. One of the best sources is these guys:
http://www.drivetrainspecialists.com...ile/index.html
Old Apr 12, 2007 | 07:22 AM
70Wcars's Avatar
Also try Super Cars Unlimited in Oregon for the gears and posi units. That is if you have the Olds 12-bolt.
Old Apr 12, 2007 | 12:17 PM
wj67442's Avatar
Your right Dan Super Cars Unlimited is a very good source !!!
WJ
Old Mar 20, 2008 | 08:50 AM
Ndn_GivR's Avatar
A good place to look is here.
http://www.accuautoparts.com/index.jsp its pretty good.
Old Mar 21, 2008 | 07:58 AM
Originally Posted by Ndn_GivR
Wow, I'm impressed. Have you actually used them? They seem to know the difference between Type O and other axles and list parts for them. Good find.
Old Mar 21, 2008 | 09:08 PM
Ndn_GivR's Avatar
Wink cheap gears.
Naw, hav`nt got that far... yet, I have 87 Cutlass, working on the rear suspension, next will be the front. Then i`ll tackle the rear end, going with a3.42 Eaton. Gas prices are freakin me out, was looking into a 455 swap, now im considering a Grand National motor.
Old May 14, 2008 | 04:01 PM
my67olds's Avatar
I have had great luck with OldsmobilePerformance out of the east. Andy Miller the owner has been helping me with the 67 Cutlass fuel system, timing/plugs and cooling system. I would refer him to any Olds owner.
2doorjunkie
Oct 26, 2011 10:49 AM
mike623
Jan 22, 2011 07:13 AM
dhartley72
Oct 29, 2010 05:29 AM
monzaz
May 29, 2010 08:46 PM
Kidcutty
Drivetrain/Differentials
Feb 4, 2010 05:01 AM
