Change 1972 Cutlass Supreme open Diff to LSD
Old Feb 11, 2024 | 10:09 AM
SRV8's Avatar
Hi I would like to change from a normal open differential to a limited locked one, but I only want to change the differential itself and not the gear ratio, is it possible to pull the axles out to change the differential without changing the bearings and seals i.e. I would just put them back in after changing the differential?
Will this diff fit 1972 OLDSMOBILE CUTLASS Yukon Gear & Axle YDGGM8.5-3-30-1 Yukon Gear & Axle Dura Grip Positraction Carriers | Summit Racing
Old Feb 11, 2024 | 10:32 AM
Your axle uses the common Chevy 8.5" ten bolt carriers, and so long as your gears are 2.73 or numerically higher this will work. Yes you can simply pull the axles and reinstall them. The MIGHTASWELLS would suggest that now would also be a great time to change bearings and seals, but since there are no C-clips, changing them later is relatively easy.
Old Feb 11, 2024 | 10:39 AM
SRV8's Avatar
Hi Joe standard axle have 30 spline right ?
Old Feb 11, 2024 | 10:43 AM
Qwik71442's Avatar
Full-time Taxpayer
You should have 28 spline if it’s an untouched rear. You can use the 30 spline but will need to replace the axles.
Old Feb 11, 2024 | 10:58 AM
SRV8's Avatar
Hi it is untouched, so 28 spline, thank you very much
travisbeamon
Jan 17, 2022 01:38 PM
JRev
Jan 2, 2022 12:55 PM
72Supreme4Speed
Aug 21, 2018 11:00 AM
StickW31
Oct 22, 2014 08:46 AM
Oldsguy
Jul 21, 2009 06:05 PM
