cast 9792977 rearend
Old Jan 26, 2013 | 07:49 PM
CHUCKOLD's Avatar
Friend got rearend today. Not expert on numbers. Wants to put it in a 1972 chevelle. Pulled cover and it's a posi/springs. 10 bolt. I asked for cast date and he thinks it's L-19-5. Will it work?
Old Jan 26, 2013 | 09:16 PM
Would be much easier if you identified what car it's coming out of instead of the casting. Most of the 68 -72 A body rear axles will interchange among brands.
Old Jan 27, 2013 | 04:00 PM
CHUCKOLD's Avatar
The rear end turned out to be a 1968 Tempest 293 10 bolt posi coded YD.
Hollander book i have showed will work. Just have to use u bolts rather than bolts with caps. Told friend he got a deal. Rear will fit alot of models and flyer posi is good road setup. 400 bucks for complete and can put rite in his car!
Old Jan 29, 2013 | 04:50 AM
507OLDS's Avatar
That date says that it was cast in late 1965,so it would have come in a 66.
I'm not sure aboiut putting it right in the car.Has it been serviced or rebuilt at all?If not,that thing is over 45yrs old.You start running it again,as-is,and it won't take long before it needs attention.Just don't expect the world out of it.
Old Feb 2, 2013 | 08:58 AM
CHUCKOLD's Avatar
Cast date of housing came out to be Dec.67 . gear dates were Nov. 67. Code was YD .
Old Feb 2, 2013 | 09:24 AM
507OLDS's Avatar
Did it say L-19-5,or was the 5 a 6,or something else?
Old Feb 13, 2013 | 03:32 PM
CHUCKOLD's Avatar
L 19 7 turned out to be a 68 rear end
Old Feb 13, 2013 | 07:03 PM
monzaz's Avatar
lol
Yep another miracle 45 year old rear to handle 500HP. Cross them fingers.... Jim
Old Feb 13, 2013 | 07:19 PM
507OLDS's Avatar
OK.In your original post,you said it was cast L-19-5. That is what I went from.
Old Feb 15, 2013 | 10:56 AM
monzaz's Avatar
Brian, I am on your side. Too old a rear to run even in a regular build car. Spend some money and get the rear rebuilt. These cars are now 15K - 20K in good used older restored condition. If you have one you can afford the rebuild. Jim
Old Feb 16, 2013 | 05:24 AM
CHUCKOLD's Avatar
Guy miss read casting number till he cleaned his glasses. I would rebuild myself like your suggesting. While all together and not broke. Investment right now is only 400 dollars. thank you guys
bmcrawford
Nov 8, 2018 02:14 PM
Daverd
Aug 17, 2010 10:56 PM
2blu442
Sep 26, 2009 06:50 PM
dan2286
Jul 16, 2009 07:14 AM
American Lead
Mar 13, 2009 07:22 PM
