Can someone help ID my posi? 402227 T3 OFD4
Old Jan 23, 2012 | 08:59 AM
jfldesign's Avatar
Can someone help ID the posi by year car and model? It's a 3:90 - 3:91 by revolution calculation and the markings are as in the title, 402227, either OFD4 or CFD4 on the main housing with an upside down T3 on the passenger side tube. Thanks in advance,
Joe
Old Jan 24, 2012 | 04:15 AM
507OLDS's Avatar
It's a 68-69 T3 3:91 posi rear.Cutlass,442 12-bolt O-axle.
Old Jan 24, 2012 | 11:40 AM
jfldesign's Avatar
442 posi rear
Brian,
Thanks! That's what I was hoping. Now after I get the car running, just bought it, owner says hasn't run in 10 years, we'll see what kind of shape its in. Eventually I'll pull it apart and service it.
R, Joe
Old Jan 26, 2012 | 04:52 AM
monzaz's Avatar
68 69
If you pull the axle shaft you will see if it is a 68 or 69
sealed bearing with the seal in the axle tube - 1968
oil bearing from the center section with the axle/ wheel seal on the axle shaft out board fo the bearing it is a 69 -70 rear.
Jim
JD
Old Jan 26, 2012 | 05:41 AM
jfldesign's Avatar
Axle
Jim, Thanks!
sbFALL63
Drivetrain/Differentials
Dec 22, 2012 07:52 AM
sbFALL63
Aug 10, 2012 11:06 AM
jfldesign
Jan 23, 2012 06:28 PM
sbFALL63
Aug 27, 2011 09:25 AM
chevelless
Jul 3, 2011 03:18 PM
