Help ID my posi - 402227 T3 OFD4?
Old Jan 23, 2012 | 08:57 AM
jfldesign's Avatar
Can someone help ID the posi by year car and model? It's a 3:90 - 3:91 by revolution calculation and the markings are as in the title, 402227, either OFD4 or CFD4 on the main housing with an upside down T3 on the passenger side tube. Thanks in advance,
Joe
Old Jan 23, 2012 | 11:39 AM
1970cs's Avatar
Lansing built
axle
I found T3 Axle code with matching 3.91 axle ratio limited slip chart says series 31,35,32,36,42 and 4400 series Oldsmobile, asy# 4027777 axle sub asy, numbers are fairly close to yours. Somebody correct me if i am wrong here but some of those series come back to 88's
Source 1969 Oldsmobile chassis service manual.
Regards, Pat
Old Jan 23, 2012 | 11:48 AM
jfldesign's Avatar
442 w series
Thanks Pat. I found miscellaneous information pointing toward the 1970 442 W- series. It's hard to confirm though.
R, Joe
Old Jan 23, 2012 | 12:57 PM
1970cs's Avatar
Lansing built
R, Joe
Hi Joe,
1970 CSM shows that TO code For 3.91 limited slip for non W-machines also for TJ for W-machines and SZ for aluminum axle plus part numbers for 70 axles begin with 405xxxxx. see pages 13 and 14
http://wildaboutcarsonline.com/membe...2_-_Sec_5_.pdf
Old Jan 23, 2012 | 01:31 PM
wmachine's Avatar
Trying to remember member
Originally Posted by 1970cs
Hi Joe,
1970cs, pm sent
Old Jan 23, 2012 | 01:40 PM
64Rocket's Avatar
T3 is for '68 '69 3.91 ratio, 442 Cutlass
Gene
Old Jan 23, 2012 | 01:48 PM
jfldesign's Avatar
442 posi rear
Gene, Thanks.
Joe
Old Jan 23, 2012 | 03:54 PM
joesw31's Avatar
The T3 code was in 1968 and 1969 442 with 3.91 with disc brakes.
Old Jan 23, 2012 | 06:28 PM
wmachine's Avatar
Not to sidetrack this thread, but more as a matter of Olds trivia, I *believe* '67 was the only year where there were W30 specific axle codes.
sbFALL63
Drivetrain/Differentials
Dec 22, 2012 07:52 AM
sbFALL63
Aug 10, 2012 11:06 AM
jfldesign
Jan 26, 2012 05:41 AM
sbFALL63
Aug 27, 2011 09:25 AM
chevelless
Jul 3, 2011 03:18 PM
