broken rear vent cap
Old Jun 7, 2014 | 09:17 PM
72cuttys's Avatar
Well, I was rolling the rear over on top of the jackstands to clean the other side, and I snapped off the vent cap flush with the axle tube. If I run without a vent cap will it cause any type of damage?
Old Jun 7, 2014 | 09:44 PM
The vent prevents water and dirt from getting in, so while you can run without it, over time there may be a build up of moisture/dirt in your diff oil. If you really don't want to replace it, I would put a dab of sealer over the hole to prevent anything from getting in.
Wow, I just looked and saw some Olds resto houses want $13 or so for one, whereas this place has one for ~$4:
http://www.cascade4wd.com/store/inde...oduct_id=30516
Old Jun 7, 2014 | 10:06 PM
72cuttys's Avatar
The only reason im hesitant to replace it is because the bottom of it is still inside the axle housing. If I try to get it out, im afraid of any plastic pieces/shards falling down into the housing. I might try to find the smaller breather, and press it into the leftovers of the old one...
Old Jun 8, 2014 | 05:46 AM
ELY442's Avatar
I just ordered (2) of those vents from Motorcity Supercars/Inline Tube for $6.50 ea. Its real easy to pop them off. I use a cutting pliers and get a firm grip around the vent and pry it off. Oh yea, they make (2) different sizes so make sure you get the right one. I do believe its 3/8 and 7/16.
Old Jun 8, 2014 | 06:22 AM
I would replace it prior to reinstalling the housing back in the car. It should be very easy to remove the broken piece.
Old Jun 8, 2014 | 06:29 AM
tru-blue 442's Avatar
Old School Olds
Just a thought but you may try a
bolt extractor. If you can get a few turns
on it, before it starts to spin the broken piece,
you may be able to pop it out.
Old Jun 8, 2014 | 07:19 AM
It also acts exactly as it's name implies to limit internal pressure as the differential heats up. I would remove the broken piece aNd replace it. The OEM vent on my car was easy to pop out. I noticed it has a green cap compared to the repro ones.
Old Jun 28, 2014 | 05:49 PM
JohnnyBs68S's Avatar
If you seal this vent, won't it blow lube out the seals when the rear heats up?
Old Jun 28, 2014 | 06:12 PM
jpc647's Avatar
I don't think I even have one of these breathers. Is this where you fill the diff up from? I've got one of those plugs in there that you put like a 3/8 extension to remove it.
Where does this breather go?
Old Jun 28, 2014 | 07:25 PM
Any fluid under conditions of pressure and temperature will find the weakest place in the axle assembly and likely do that. A replacement vent cap is the best way to go IMO. Try tru-blu's suggestion to extract it. This piece is a type of nylon plastic.
Old Jun 28, 2014 | 07:29 PM
Old School Olds
The 3/8 plug is a fill/check.
The breather plug is on top, pass.side.
Old Jun 28, 2014 | 07:39 PM
That is the bung you use to fill the differential with gear oil. Yes it's a 3/8" socket extension.
Here's a picture of the OEM one on my 72. File pics from when I rebuilt it.
Old Jun 28, 2014 | 07:53 PM
Old School Olds
That rear is a thing of beauty Allan.
Old Jun 28, 2014 | 08:41 PM
jpc647's Avatar
Thanks for the explanation.
Thanks for the picture Alan. Next time I'm under the car, I'll look, just to see. Sorry for the thread hi-jack.
84oldsDelta88
20
Jan 12, 2016 01:36 PM
L77F85
Jun 23, 2015 10:24 PM
197064buickspec
Aug 10, 2014 06:18 PM
dyscookn
Mar 29, 2008 11:31 AM
