Bolt-in rear end swap?
Old Jun 3, 2014 | 11:36 PM
Erinyes's Avatar
I've been told that the rear end from a 57-64 Olds-Pont (9.3) is a bolt-in swap into my 53 88. Can anyone confirm this?
I just found a 64 Catalina Safari wagon with the rear end intact for cheap, good only for a few parts. If the rear end is an easy swap, it would be worth checking out closer.
TIA.
Old Jun 4, 2014 | 05:58 AM
66400's Avatar
Doesn't the 64 Pontiac have coil springs while the 53 Olds has leaf springs?
Henry
Old Jun 4, 2014 | 06:22 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Are you just talking about swapping out the center section (the pumpkin) or the entire rear end?
Old Jun 4, 2014 | 06:23 AM
Erinyes's Avatar
Hmm. Yes, apparently so. That would put a damper on the whole "bolt-in" scenario...
Oh, well. It's so rare to see something like that pop up within a hundred miles, in Montana, that I got over-excited.
Old Jun 4, 2014 | 06:28 AM
Erinyes's Avatar
The whole rear end. It would be fun to have posi at some point, which isn't an option at all with the original rear but is with the 9.3, as well as being monstrously strong.
350TurBRO
Sep 12, 2014 11:52 AM
oldjunk
Apr 26, 2009 10:26 PM
olds cutlass
Drivetrain/Differentials
Apr 9, 2009 05:44 PM
loosecannon39
Feb 13, 2009 03:34 AM
sscutlas
Sep 4, 2007 10:20 PM
