Best choice- Corporate 10 bolt or O?
Old Aug 2, 2008 | 05:08 AM
ziff396's Avatar
What are the pro's and cons of each? I have a 72 corporate open with 2.73's and also a O rear with 2.56 gears out of a 70. Both are out of Cutlass's.
Which would be the best choice to rebuild and convert to posi units with 3.42 gears? I'll be running a strong street 455 with a turbo 400 trans.
Thanks for any help!
Kevin
72 Cutlass in progress.
Old Aug 2, 2008 | 09:01 AM
BILL DEMMER's Avatar
Just the facts...
from what i've always heard, the availability of parts for the O are poor.
i know the guy that did mine thought more highly of the corporate r.e. and had some difficulty locating the parts for my O r.e. but, he got it done on time and under budget.
bill
Old Aug 2, 2008 | 10:15 AM
Strenght-wise they are pretty much equivalent. Both use an 8.5" ring gear with ten bolts. The parts availability pushes the corporate axle to the top.
Old Aug 2, 2008 | 11:27 PM
Just the facts...
joe,
i thought the type-o was 8.2" and only used 10 bolts on the ring gear to carrier vs. the corporate 12 bolt with an 8.5" and 12 bolts for the ring gear to carrier.
bill
Old Aug 3, 2008 | 07:59 AM
Run to Rund's Avatar
Thre were type B and P 8.2s used in 64-7. Type O was 8.5, ten 7/16 left hand threads (iirc) on the ring, 12 bolt cover, from May 66-70; thru 68 with 31 spline, 69-70 with 28 spline axles. Corp 8.5 was mostly 71-2 in terms of mounts for 64-72 A bodies, with 10 cover and ring gear bolts.
For best strength, the corp 8.5 has the most stuff available, as noted above. Many weld the tubes to the center section with nickel rod, but it should be done by someone good and carefully to avoid drawing the tubes out of alignment.
I did a cost comparison a couple years ago with the 8.5, 12 bolt Type C, and Type F ten bolt (9" Ford). Mild builds--you can save if you already have something to start with. Full builds, pretty much the same cost for all of them.
Old Aug 3, 2008 | 12:00 PM
Originally Posted by BILL DEMMER
joe,
bill
Bill,
The 8.2 is the earlier axle. The 67-70 Type O is 8.5", 10 bolt ring gear. The Corporate 8.5 is also ten bolts on the ring gear. The Chevy 12 bolt is an 8.875" ring gear with 12 bolts.
67442nut
Jan 6, 2017 09:09 AM
Mikes442
Drivetrain/Differentials
Jan 31, 2014 03:57 AM
mfpm7232
16
Nov 8, 2013 04:43 AM
71cutlass350
Jul 27, 2013 01:20 PM
ah64pilot
Aug 28, 2012 07:15 AM
