Axle Swap Question.
Old September 16th, 2010 | 07:26 AM
76Supreme350's Avatar
Axle Swap Question.
Would the axle from my 76 cutlass fit a G Body. The upper arms are the same part number and the lower arms are only 1 number off (for the part I was looking it). Is the reason the lower arm has a different number because of the design of the arm on the frame side or the axle side. If it were just the frame side would the lower control arm for the gbody work to make it swap into my 80 LeMans. Thanks.
(For those who don't know the 80 LeMans and 80 Cutlass are exactly the same.)
Old September 16th, 2010 | 07:44 AM
507OLDS's Avatar
It will not swap directly,plus the 76 rear is wider than a G-body rear.There are control kits available to swap the 64-72 A-body rear into a G-body,but not the 73-77 due to other differences in the mounting points.
Old September 16th, 2010 | 08:09 AM
Darn
Thanks for the response
mphyle0927
Drivetrain/Differentials
September 29th, 2013 09:45 AM
radcar
March 5th, 2013 04:57 PM
ACID64
January 18th, 2012 10:46 PM
'69CutlassVert'
August 25th, 2011 08:19 AM
cutlasssupreme71
February 22nd, 2011 12:40 PM
