Anyone with a 1969 Chassis Service Manual?
I am looking for the exact measurement of what the propeller shaft (driveshaft) should be for a '69 2dr Cutlass w/ TH350. Using my '68 manual it specifies a "THM" for said car should be 55.1" but I forgot that the TH350 was not avail until '69. The measurement in the '68 manual is listed in the "Propeller Shaft" section 4A-1 in a chart at the end of that section.
Any help would be greatly appreciated since the correct driveshaft is all I need to drive my Cutlass for the first time since I've owned it (1yr).
Thanks!
Thanks!
Thanks!
Thanks!
So a driveshaft from a '68 2spd would also fit a '69 TH350 in a 2 dr? Length and spline?
'68 Chassis Manual lists the following:
F-85
Sedans or wagons - T.H.M. ------- 59.10"
Sedans or Wagons - M.T. or J.T. -- 60"
Coupes - T.H.M. ------------------ 55.10"
Coupes - M.T. or J.T. ------------- 56"
Vista Cruiser M.T. ----------------- 65.04"
Vista Cruiser T.H.M. --------------- 58.26"
I've been talking with a guy who has a driveshaft from a '68 Cutlass 2dr that had a 2spd trans and he measured the length center to center (of u-joints) and it measures 55" +/- 1/16th so I'm assuming he has the 55.10" driveshaft. Will that work or do I need the 56"?
Thanks Joe!
F-85
F-85
MaxDog
July 21st, 2011 11:50 AM
Tony72Cutlass'S'
March 11th, 2011 10:35 AM
