72 Supreme Convertible - rear end Identification
Old Apr 13, 2025 | 07:04 PM
flameorange's Avatar
Hi folks, newbie working my way through a frame off restoration 72 Supreme Convertible, was trying clean up rear diff this afternoon, 50 year old zeibart undercoating. Can someone help ID or decode the numbers I found while cleaning it up. What rear end do I have, GM Vintage vehicle services says it is a 2.73 ratio, what does the no on the diff cover mean, as well as the ‘A’ and sideways U, and the yellow paint? And the other numbers on the fron lower face of the rear end? ✌️(Canadian sold car, build date 18 Oct 71).
What rear end?
What rear end?
Yellow paint rear of passenger axle
Decode?
Decode?
The A and the U, and more yellow paint…
A thought it should be O?
Yellow paint?
Yellow paint?
Decode?
Decode?
Old Apr 13, 2025 | 08:35 PM
69CSHC's Avatar
Decode?
8.5 10 bolt and SA is 2.73 open.
Page 1 and 18 here. https://oldcarmanualproject.com/manu...Ill/Group5.pdf
B288 1
Originally Posted by 507OLDS
SA = 2:73 non-posi
B = Buick plant
159 = 159th day of the year
2 = 2nd shift
You have the A-casting,as I call it.It has a large "A" on the top of the pumpkin,and an "A" on each side(frontside),where the tubes go in.These rears came in the 71-72 Cutlass/442 that were not built in Lansing,and they came in all 71-72 Skylark/GS cars.If you have the original drums,you will notice a small Buick trishield on the outer edge of the face.
Post #4 here https://classicoldsmobile.com/forums...cutlass-63583/
So yours is Buick Plant 288th day of year and 1st shift.
Old Apr 14, 2025 | 05:02 AM
Not Lansing!
Cool thanks I have the Buick rear end.
Date code 288=Oct 15 1971, which lines up with the broadcast sheet build date of Oct 18.
Not Lansing is interesting to me, as cowl tag says LAN?
Canadian sold car, I was able to get from GM Vintage Vehicle Services rhe Vehicle report which indicated Production Plant St. Louis Missouri, but my cowl tag says LAN.
thanks ✌️
My cowl tag - LAN
My cowl tag - LAN
B288 1
Aug 18, 2023 06:04 AM
Cwh
Paint
Jul 2, 2023 07:08 AM
Olds68swede
Drivetrain/Differentials
Jan 11, 2022 01:52 PM
tkcutlass
24
Mar 27, 2021 07:42 PM
DewChugr
Oct 12, 2016 09:26 PM
