Stamped numbers on w27 housing
Old Apr 24, 2025 | 09:27 AM
greg.durham100@gmail.com's Avatar
Cast numbers on w27 housing ( edited original title said stamped numbers)
Is this a real w27 pumpkin?
I can’t seem to find how to identify a true w27, I’m just looking at pictures. Trying to decide if I should make a 4 hour drive to look at this Cutlass S.
Last edited by greg.durham100@gmail.com; Apr 25, 2025 at 05:09 AM. Reason: Should say cast numbers, not stamped
Old Apr 24, 2025 | 11:18 AM
OLDSter Ralph's Avatar
Did the owner tell you it was a W-27 ?
#1 the numbers you are showing are CAST into the housing, they are not stamped.
#2 This looks like it was painted and has a clear top coat.
#3 This should help you figure it out
https://www.google.com/search?client...ifferential%22
Old Apr 24, 2025 | 12:25 PM
Thanks for the info
No they didn’t say it was a w27.
Yes the numbers are cast, my mistake.
i looked at some of the info on your link.
Was the w27 the only 12 bolt Oldsmobile produced?
Old Apr 24, 2025 | 01:38 PM
VC455's Avatar
Barely Registered
There can be confusion over the terms 10-bolt and 12-bolt in referring to Oldsmobile Cutlass differentials of this period.
The Oldsmobile-produced differentials all have a 12-bolt cover and 10-bolt ring gear.
Old Apr 24, 2025 | 02:29 PM
Here's a thought. Does a magnet stick to it?
Old Apr 24, 2025 | 02:33 PM
I'll add that every single Type O axle that Olds made from 1966 to 1970 used a 12 bolt cover. Despite that, the A-body versions used TEN bolts to hold the 8.5" ring gear to the carrier. The ones used in the full size cars used TWELVE bolts to hold the 9.375" ring gear to the carrier. Neither one has anything in common with the Chevy 12 bolt axle.
Old Apr 24, 2025 | 02:47 PM
I’m 4 hours away
Old Apr 24, 2025 | 02:51 PM
I think you are correct
I think it’s painted and has clear coat. You can actually see reflections on the paint.
Good eye brother
Old Apr 24, 2025 | 03:27 PM
I think I found the casting # for the w27
See be
From an inspector
From an inspector
A car that sold recently
Old Apr 25, 2025 | 08:45 AM
joesw31's Avatar
This the last W-27 that I worked on.
Old Apr 28, 2025 | 06:30 AM
oddball's Avatar
The ribs are very small. It's probably a normal iron pumpkin that's been painted.
Old Apr 28, 2025 | 12:38 PM
@joesw31
Thanks for the picture.
Now I know the facts.
the inspectors report I posted had 2 numbers. One for the cover and one for the carrier.
W27 cover #406785
W27 carrier #406784
if that info is anywhere on this site, I couldn’t find it. But that’s just me
Old Apr 29, 2025 | 05:47 AM
monzaz's Avatar
Just get a magnet...THAT will tell you for sure. ALUMINUM is non magnetic....
455 Olds 442
Jan 24, 2015 09:30 AM
bobb
Apr 11, 2011 06:41 PM
mono-plane
Oct 15, 2009 04:40 PM
Boldsmobile
Apr 8, 2009 07:51 PM
ragtop442
Apr 6, 2009 04:32 PM
