72 TO Axle Conversion - Finished Product
Old Jan 16, 2012 | 07:00 AM
costpenn's Avatar
Completed the 3:42 TO Limited Slip rear end conversion for the 72 442 vert 455 MT I'm building. Started with the original 2:73 SA open unit - dated coded 70th day of 1972. Was in pretty good condition - had never been out of the car but had been spray canned about 8 times. It appeared to me the cover had never been off - and boy what a stink when I first opened it up. Somewhere along the line the RH wheel bearing had been changed out, other wise was a solid run of the mill unit that served as a foundation for the conversion.
Breakdown of costs/parts involved will be added in a later post.
Old Jan 16, 2012 | 09:45 AM
costpenn's Avatar
Here's a list of everthing used in rebuilding this unit along with price and source. Of course, labor is costed for the "love" of it (meaning free!) as well as my long time friend's expertise in setting up the ring & pinion and incidentals like paint are not costed.
Rear Brake Hardware Kit
Auto Zone
5.99
Rear Brake Shoes
Auto Zone
15.99
Rear Wheel Cylinders New
Auto Zone
15.98
Pressing Rear Wheel Bearings
D & D Auto
40.00
Rear Wheel Seals
D & D Auto
11.70
3:42 Ring & Pinion & Diff Rebuild Kit
Ebay
195.95
Sway Bar Shims
Fusick
20.00
Anti Spin Additive
GM
8.99
Rear Axle Vent Valve
GM
6.93
Rear Axle Bumper Kit
ILT
19.55
Rear Brake Lines (Stainless) Kit
ILT
35.00
Rear Trailing Bolt Kit
ILT
29.00
Sway Bar Bolt Kit
ILT
16.00
Various Rear End Decals
ILT
8.00
Posi Carrier - 2:73 & up - NOS?
NTOC Member
100.00
Synthetic 80-140W Diff Oil
O'Reilly
25.98
Rear Brake Adjuster Kit - Left
Rock Auto
8.42
Rear Brake Adjuster Kit - Right
Rock Auto
8.42
Rear Brake Hose (Rock Auto)
Rock Auto
9.92
Rear Coil Spring Insulators
Rock Auto
7.27
Rear Coil Springs
Rock Auto
67.46
Rear Control Arm Bushing Set
Rock Auto
38.55
Rear Drums
Rock Auto
62.00
Rear Wheel Bearings
Rock Auto
27.21
Total for all parts was 695.10
Ring & Pinion Kit from Motive included carrier and pinion bearins, pinion seal, ring gear bolts, crush sleeve and cover gasket
Finally, we stamped the tube with the TO - and yes, it will always be represented as such.
Old Mar 3, 2012 | 11:18 AM
stlbluesbrother's Avatar
Just noticed this post.
Alway interesting to see cost break down on restoration/builds. Thanks for sharing
Old Mar 3, 2012 | 11:43 AM
Beautiful job on the resto/rebuild. Looks like it just came from the factory. Nice cost breakdown, does it also include shipping?
I have my Series 11 posi ready to go, just haven't decided on the final ring/pinion. 3:08, 3:23 or 3:42. Unless I get a 455/400 to slide in it will probably be a 3:08 or 3:23
From the sounds of your original SA code date stamping your car was built just about a month before mine. What factory? Mine is Lansing.
Those the wheels going on it in the background? Looks a lot like Matador Red?
Old Mar 3, 2012 | 12:20 PM
Econow's Avatar
So I hear "posi" and "Limited slip". I a limited slip cheaper to do then a posi? Is it also easier to drive with the limited slip - cornering? I am interested in which one to add. Thoughts?????
Old Mar 3, 2012 | 01:00 PM
The two terms are interchangeable. The benefit of posi or limited slip is to provide power to both wheels when the normal drive wheel starts to 'slip' or break traction. When the traction equalizes or returns to normal, the clutches in the posi returns the normal drive wheel (right rear) to be the only one 'driving' or supplying power to move forward.
Is it easier to drive? When you need it, yes. For normal driving? no. Note: if you don't change the gear oil or additive at regular intervals as called for by maintenance cycles, the car will start 'chucking' when you turn sharp corners. (Kind of like a shuddering coming from the back end).
If you want a lot more info on the posi/limited slip? Get in touch with Monzaz or 507OLDS on this site. They are specialists.
FYI, cost factor? Depends on what you buy, from whom, used or new, and the type of application it will be used for.
Old Mar 4, 2012 | 08:21 AM
monzaz's Avatar
limited slip or posi
Limited slip is industry standard for traction to both the left and right rear differential. Ford Gm Or Mopar Amc etc.
Posi - Is a Chevy term given to their division to basically nickname limited slip
Sure grip would be Mopar limited slip
safety track is Pontiac's limited slip
ANTI SPIN - Is your Oldsmobile term for limited slip.
Twin Grip is AMC's term for limited slip
SO I hope this helps you understand how to use your terms and what they all stand for. Jim
J D
Old Mar 4, 2012 | 08:32 AM
Econow's Avatar
So there is only 2 types of rear ends "open diff " and " limited slip ". I thought there was a true " posi " that is always " locked " into both axles - like if you weld the spider gears for a demolition car.
Thanks Guys
Old Mar 4, 2012 | 12:22 PM
Thanks Guys
Actually there are 3 types of diffs (4 if you count a spooled solid axle). You know the 1st two. The third and most popular at the track is the 'locking' rear which will provide the 2 burnout streaks you're probably thinking of. Does the term 'Detroit Locker' come to mind? It's by far the most popular and well known.
From 'offroaders.com'
A locking differential or "Locker" uses a mechanism that allows left and right wheels to "lock" relative to each other and turn at the same speed regardless of which axle has traction and regardless of how little traction a slipping wheel has. In this state, the axle acts more as a "Spool". This means traction can be sent to a wheel that may be planted firmly on the ground while the other wheel of the axle is completely off the ground. In this situation an open differential will spin the free (lifted) wheel sending absolutely no torque to the wheel in the ground. A limited slip in this situation will send some torque to the wheel on the ground but possibly not enough to provide any forward momentum.
Old Mar 5, 2012 | 06:41 AM
costpenn's Avatar
Allan,
Thanks - coming from what I've seen of your car that's quite a compliment
1) Shipping is not included on all the parts costs. Looking back at my spreadsheet, I approximate 35-50 bucks more all in on the shipping if I apportion it correctly. It REALLY pays to make a master list of eveything you need (as much as possible) and order it at once - freight costs are getting to be a larger percentage of the total procurement cost.
2) VIN indicates mine is a Lansing car -was orginally sold new in Wisconsin.
3) The car is a code 65 Flame Orange/White top/White interior car. I've gone slightly brighter in the color - almost a Hemi Orange. The wheels are incorrect - they have the push on center caps. I wish I had a do over on that since everything else on the car (with the exception of the heads, and seat belts) will be the correct components for a 1972 442 vert 455 W25 4 spd non air car.
Old Mar 5, 2012 | 11:51 AM
What are your last 6 on the VIN? Mine is 208783 Built April 7, 1972.
Are you looking for 1972 coded seatbelts? I think I know someone who has a set. I'll check.
re: the wheels? I hear you. I'm one of those guys who believes a SS11 is a bolt on wheel center with argent wheel color, and SS111 are clip on with body color wheel. I have both styles; and at a quick glance you could miss the difference. If anyone wants to argue the point, I don't care anymore because it's been re-hashed to death - ad nauseum.
I know that most judges don't look too close at them, but it's nice to know that you've got the 'right' ones, even if everyone else 'doesn't know'. That make sense to you? FWIW? The clip on center caps have 1 redeeming feature the bolt ons don't. When you undo the wheel acorns, there is a high risk of damaging the finish on the side of the bolt on caps because of how close they sit to the nuts. Snap ons sit way higher and aren't affected that way.
However, Snap ons have an annoying habit of rattling when the spring trim ring inside comes loose. 6 of 1, half doz of the other.
Love your color combo BTW. It will look stunning when it's done.
Old Mar 7, 2012 | 09:09 PM
costpenn's Avatar
Allan, my VIN sequence number is 199185 do you have a way of determining the build date from this? Thank for the offer on the seat belts, but I'm OK with the ones I had in storage.
Old Mar 7, 2012 | 09:39 PM
Well it was just before my car was built. Taking an educated guess that the assembly line would produce about 6000 cars/week. I know my car was built on April 7/10 (started on Friday evening shift, completed on Monday morning shift). If I back count from there, your car would likely have been built around the fourth week in March 72.
Look on your cowl tag. At the bottom left cowl rivet there will be a code embossed there. Something like 03D. The first 2 numbers are the month it ws built, the letter corresponds to the week (A=1, B=2, C=3, D=4, E=5). Without having a broadcast card or build sheet for your car, that's the closest I can estimate for you. Can you post a pic of your cowl tag or find that info?
Old Mar 8, 2012 | 07:50 AM
costpenn's Avatar
Allan, next time I go see the car again I'll get that cowl code - it's been at the painter's for almost 8 months now. Thanks!!
Old Apr 17, 2012 | 08:42 AM
Tony72Cutlass'S''s Avatar
[QUOTE=costpenn;359819]Started with the original 2:73 SA open unit -QUOTE]
Joe,
I just realized we have the exact same diff, i have a SA 2.73 as well. Did you do the Posi installation and bearings and such yourself?
Old Apr 19, 2012 | 03:31 PM
costpenn's Avatar
[QUOTE=Tony72Cutlass'S';395133]
Joe,
Tony, I had a good friend in the Olds club who's an amazing machinist actually do the ring gear to pinion lash spacing/set up. The posi unit I bought for it was an NOS unit (the best deal I've had on this build) so it needed no work - I really cant tell you much about it. The carrier and axle bearings are pretty easy - It's really not that complicated - go for it!!
Joe
Old Apr 24, 2012 | 06:51 AM
monzaz's Avatar
Detroit locker is still a form of limited slip... Crude and archaic but it does release in turns so it is still in that category. Same as Power trax...still releases to relieve torsion in the axle shaft.
Full spool is a tube with splines that is what we use at the drag race tracks
Mini spool is dirt track racing cheap spool can still be run with c-clips
Both these unit never let the axles slip or release in turns the tire will take all the slippage in the turns cause a bark in the tires and a bit of binding in slow turns... Not great for stock axles and you will need c-clip eliminator kit for the FULL SPOOL or a housing end made for boltin axles like 10 bolt 8.5, Ford 9", Mopar 8 3/4 etc.
If you are 80% street and 20% drag race always go with the Limited slip / locker (detroit locker, power trax) for a better street drive. If you do more street driving and freeway, do not use the locker type...manners are not as good in these applications they are more for your weekend warrior driver type that like to look cool driving to the track and back.
Jim JD
Old Apr 24, 2012 | 07:01 AM
monzaz's Avatar
Thanks Guys
POSI - limited slip
There are many types of these units-
Eaton Performance - Clutch type Preload springs (always on and working)
Auburn Borg warner- Cone type Preload springs (always on and working)
Torsen / true trac- Helical Worm gear not preload inertial type unit (best for road racing type applications)
Eaton Gov lock Auto locker - Clutch type (works under load request) Locks and unlocks when needed uses centrifugal flyweight and ramp gear system.'
Works great for truck low speed operation towing plowing ice snow off road etc. (NOT DRAG RACING)
Traction Loc - clutch type - beveled preload clutch NO PRLOAD springs (used in dodge and jeep
trac lock - Clutch type 'S' spring type preload Ford and GM
Traction lock Clutch type 9" and 8" Ford clutches larger diameter BUT only on one side...??? beveled preload plate for clutch preload. It's Ford enough said.
Jim J D
Old Apr 24, 2012 | 09:18 AM
507OLDS's Avatar
Joe,
Looks good.Just curious why you chose to stamp it TO,and not TM,which is correct for the 3:42 posi?The TO code is correct for 3:73 posi,for 71-72.
Old May 3, 2012 | 01:34 AM
costpenn's Avatar
Smile
Originally Posted by 507OLDS
Joe,
Brian I screwed up. I stamped the tube TM, then much later was finishing the detailing and had that brake drum sticker as part of the ILT kit and put it on there (It was the only one provided) and forgot it is a TM.
Old Sep 16, 2013 | 05:56 PM
cdrod's Avatar
Rodney
Torsen in 8.5" 10-bolt?
I know this thread is over a year old, but I thought it better to continue an existing thread than to start new one since there is some good background info already in this thread.
I've been reading up on "limited slip" differentials and it seems that the torsen is better suited for everyday, street driving. Do they have a longer service life and less maintenance than the eaton or auburn units, and can you put one in an 8.5" corporate 10-bolt? I'm building a Cutlass daily driver - 350, TH200-4r, 3.42 rear gears. I guess you'd call it a resto-mod as I'm modernizing many systems during the restoration process. I've never driven a posi before, but I want long service life, and dependable performance. I don't want the back tires breaking loose in the rain either.
brown7373
Brakes/Hydraulic Systems
Jun 13, 2014 05:43 PM
richeyb
Aug 2, 2011 06:40 PM
61F85Acid
Dec 8, 2010 05:05 PM
Hairy Olds
Oct 9, 2010 08:14 AM
blonzz
Sep 13, 2004 10:35 AM
