70 3.23 rear rebuild
Old Sep 10, 2011 | 04:30 AM
my442conv's Avatar
I have a 70 442 with a 3.23 open rear, I purchased a posi carrier to convert it, also a pinion bearing and seal.......do you thing i will have a problem if i use the existing ring and pinion? or should i bite the bullet (so to speak) and spring for new ring & pinion.
Old Sep 10, 2011 | 05:09 AM
joesw31's Avatar
If your gear set looks good, then, there should be no reason to change it. And should have no problems. Be sure to change both pinion bearings, measure the back lash, and a take a pattern reading before you take it a part.
For your axle bearings. That would be A9 or set9. What ever you do by a good quality bearing as I have had problems with the so called house brand bearings.
Old Sep 10, 2011 | 05:26 AM
my442conv's Avatar
Joe,
Thanks,,,,,,,,, i will definitely do that once i open it up
Old Oct 4, 2011 | 05:31 PM
m455sx's Avatar
Olds Nut
my vert is open rear as well and it sucks. What would happen if i go with 373 gears with the AC on?
Old Oct 5, 2011 | 12:39 AM
my442conv's Avatar
if you increase your rear to a 373,.....your out come will be higher rpms ( OVER 3g) on the highway.
Old Oct 5, 2011 | 12:49 AM
svnt442's Avatar
And you can't put a 3.73 in an O axle as that ratio is not made for it. It would either be a 3.42 or a 3.91.
If you want a 3.73 you'll need either an 8.5 10 bolt or a chevy 12 bolt.
Old Oct 5, 2011 | 03:54 AM
m455sx's Avatar
Olds Nut
Sorry, The question i should of asked why is the an rpm limit through the rear gearing for A/C cars. Lowest gear availible for A/C cars was 3:23 ratio.
Old Oct 5, 2011 | 04:42 AM
507OLDS's Avatar
An AC car could have anything from a 2:56 to a 3:42. The SX cars were known for having the smaller gears.
Old Oct 5, 2011 | 05:07 AM
m455sx's Avatar
Olds Nut
According to literature for 1970 323 was lowest gear allowed. I will double check on this info.
Old Oct 5, 2011 | 05:20 AM
507OLDS's Avatar
The 3:42 was optional on an AC equipped car.Anything higher than that would void certain warranties,if it was ordered.
Old Oct 16, 2011 | 03:26 PM
m455sx's Avatar
Olds Nut
According to the factory option list for 1970 Cutlass/442 the 3:42 gear was not availible with A/C. Visevera on the A/C box it says N.A. with 3:42 geaR
Old Oct 18, 2011 | 05:37 AM
507OLDS's Avatar
Not sure what list you are looking at.The 3:42 gear was optional with a 455 AC car.Two of my previous 70 W30 autos with AC had the 3:42's ordered with them.The other ones I have had,came with 3:23's.A friend had one with 3:08's.
I did meet someone about 10yrs ago,who had a 70 W30 auto,with AC,and it was specially ordered with 3:91's.
The 3:23 was the standard gear for a 455 AC car though,unless ordered differently.The 3:42 was optional.
Old Oct 19, 2011 | 02:10 PM
m455sx's Avatar
Olds Nut
I have the original 1970 Oldsmobile wholesale car order 4-4-2 model form for when you can select any option you would like from 1970 marked and filled out by the original owner. I also have a copy of the orginal book called Salemens prices, equipment etc. The same book the salesmen carried around in 1970 to shown what accersories and option cost and what was availible. Actual writing on form as quoted "G92 3.42 to 1 performance rear axle package-extra cost- includes anti-spin and heavy duty radiator(N.A. with "C60" or "Y72")
The option for air conditioning "C60" says C60 air conditioner (N.A. with "M21","G88" or "G92".
I am just repeating or quoting information in my hand. Please forward e-mail address as i can forward digital photos of paper work.
Old Oct 19, 2011 | 02:12 PM
m455sx's Avatar
Olds Nut
I almost forgot i still need posi for my 442 please send me pricing asap so i get get on the installation.
Old Oct 19, 2011 | 02:16 PM
droptopron's Avatar
delete
I would think Mr Trick would know when it comes to gears. He is the Differential Svengali.
Old Oct 19, 2011 | 02:23 PM
m455sx's Avatar
Olds Nut
Oh i agree!!!, i was just stating the facts from the paper work in front of me. I have all original 1970 paper work from when the car was purchased, including trade in and loan papers.
Old Oct 19, 2011 | 02:39 PM
507OLDS's Avatar
We might be trying to compare the options/availability of the SX to the 442/W30.The SX could be had with a 2:78.
Old Oct 19, 2011 | 03:00 PM
m455sx's Avatar
Olds Nut
I am talking about 442's. Either way wasn't avaible on f-85's to 442's according to paperwork. But i am sure anything was possible!! It Was the 70's!!
Old Oct 19, 2011 | 03:20 PM
stevengerard's Avatar
I've seen many of the same documents that state no 3.42 on AC cars, but my car does have it (no telling its original) but I know of two other folks who had W27 rearends on an AC W30 cars with 3.42s in them just like mine.
Old Oct 19, 2011 | 03:23 PM
m455sx's Avatar
Olds Nut
G95 is the 2.78 ratio???? 3.42 (G92) 3.91(G88)
Old Oct 19, 2011 | 03:24 PM
m455sx's Avatar
Olds Nut
Question is ??? Is it orignal or is it on a build sheet. Anybody can change rears?
Old Oct 19, 2011 | 03:26 PM
m455sx's Avatar
Olds Nut
wut is chi-town?
Old Oct 19, 2011 | 03:35 PM
m455sx's Avatar
Olds Nut
i will quote from the salesman liturature. C60 Air conditioner, four season-Includes heavy duty radiator. N.A. with G88 or G92. Availible with W30 only with M40,G91 and JL2. See power teams.
G88= 3.91
G92=3.42
G91=3.23
JL2=disk power front
Old Oct 19, 2011 | 08:22 PM
507OLDS's Avatar
My gold car had it on the paper.Who knows.
Old Oct 20, 2011 | 03:56 AM
chi town = chicago
jensenracing77
Jan 12, 2016 02:02 PM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
crank.it
Drivetrain/Differentials
Apr 30, 2003 07:01 AM
