67 O rear rebuild
Old Feb 2, 2024 | 07:11 PM
89biff's Avatar
67 O rear rebuild
Looking to rebuild my original rear for my 67 442. 12 bolt cover/ 10 bolt ring gear. It was originally a 3.08 open rear. would like to beef it up… replace carrier, ring/pinion, axles… full build.
any suggestions on vendors for parts?
im running a 67 Chevelle rear currently but I would like to have correct rear back in someday.
Old Feb 2, 2024 | 07:27 PM
Is this the standard 28 spline rear or the HD 31 spline rear?
Bearings and seals are readily available from most auto parts outlets.
Gears are very limited, with only 1 or 2 manufacturers and just a few ratios.
The only new carriers are Ford 8.8 units machined so O-Type gears will attach.
Axle shafts are available from the major manufactures. Just need to know what you currently have.
I would suggest contacting monzaz (Jim at JD Race.com) as he does this for a living and has knowledge of parts and availability.
Old Feb 2, 2024 | 07:37 PM
89biff's Avatar
28 spline axles
Old Feb 3, 2024 | 01:30 PM
monzaz's Avatar
28 or 31 spline olds info
3.42 and steeper can only be 31 spline in 67 68. 3.23 and down will always be 28 spline from the factory.
no 3.23 or 3.08 or 2.78 or 2.56 ever came in 31 spline
only 28 spline carriers.
NOW that does not mean it can not be done. Jim
I do have al lthe parts on the shelf in stock for the rebuild and or gear swap for the 12 Bolt olds rear.
McIntosh
Drivetrain/Differentials
Jul 30, 2020 02:05 PM
Toocool
Nov 9, 2018 08:23 AM
sirlynxbub
Aug 3, 2017 07:46 PM
bosch 68 442
Apr 10, 2011 09:04 PM
Oldsmaniac
Nov 2, 2009 07:30 PM
