67 Cutlass posi and 355 gear kit
Old Sep 21, 2016 | 04:54 PM
Is this a good deal and will it work on my car? Not familiar with rear diffs.
http://www.ebay.com/itm/252228193058#shpCntId
Old Sep 21, 2016 | 06:10 PM
steverw's Avatar
Seems like a good deal to me, i bought a new Eaton for my 8.2 P type rear and it was $550ish, rebuild kit for the rear and axle bearings seals etc from Monaz was approx 190 shipped. I kept my 3.90 gears. A local guy set it up for me for $75 bucks. Almost the same price as mine but your getting new gears, but it dosent seem to include axel bearings and seals.
As far as fit maybe Monaz will chime in or someone else who knows more than me. I can try to find envoice on my Eaton to see which part number it is.
Good luck
Steve
Old Sep 21, 2016 | 06:40 PM
steverw's Avatar
The part number for mine from Jegs is 362-19674-010, again i have an 8.2 P type rear with factory 3.90 gears. It cost me $567.99. This part number is
BP882355 R8.5PRMKT 19674-010
The 8.5 in their number makes me think maybe for a later rear, but maybe im reading it wrong.
Dont know what gear you have now, 3.08? But a 3.55 would wake it up nicely.
Im trying to help, but hopefully someone with more knowledge will chime in.
Old Sep 21, 2016 | 06:49 PM
Are you sure you don't have a Type 'O'? If so, you need to keep looking.
Old Sep 21, 2016 | 07:30 PM
I believe I have 3:08's. A friend put this same kit in his 66. I'm going to get under the car and see whats stamped on the housing and take a pic.
Old Sep 21, 2016 | 07:42 PM
steverw's Avatar
On the side of the housing there are ribs. B type has one single rib -, P type has 2 ribs that converg to a forward facing point
Last edited by steverw; Sep 21, 2016 at 07:43 PM. Reason: the whole reply didnt show up.... weird
Old Sep 21, 2016 | 07:45 PM
2blu442's Avatar
Quick and simple, the Type O has 12 bolts on the cover and its roundish. The 8.2 only has 10 bolts in the cover and at the 3:00 and 9:00 O'clock positions a C shape portion cut out of the cover. I agree with the other guys that in 1967 it could be either one.
John
Old Sep 21, 2016 | 07:46 PM
steverw's Avatar
hmmmmm dont know why my whole reply didnt show up, so i edited it to put up the missing part and its still missing.
Ill try it here. P type ribs
Old Sep 22, 2016 | 05:35 AM
Thanks, I'll check and get back.
Old Sep 22, 2016 | 07:18 AM
Here are the pics:
Old Sep 22, 2016 | 08:39 AM
That's a Type 'O'. The parts on Ebay are not what you want.
Old Sep 22, 2016 | 12:59 PM
From another recent thread I learned that Richmond Gear is again producing 3.42 gear sets for the O-Type rear.
Their catalog lists 3.42, 3.90, and 4.10:
http://www.richmondgear.com/wp-conte...n1.pdf#page=32
Available gear ratios, whether new or original GM, are fairly limited. The new gears are made to fit on the factory 3.08-3.23 series carrier.
I recommend you check with Brian (507olds) or Jim (monzaz) for parts and information.
Old Sep 22, 2016 | 02:11 PM
I sent Jim a PM and pictures. I had never in all my years of tinkering messed with the center section of a rear end. This is a learning experience for me. I figure I need to replace the pinion seal, cover seal, and rear control arm bushings. I MAW upgrade to a posi and a better gear. Axle bearings are all good, replaced a few years back.
nj_cutlass72
Nov 20, 2019 09:11 PM
507OLDS
Aug 7, 2014 07:35 PM
coppercutlass
Apr 2, 2014 07:45 PM
captjim
Mar 18, 2014 07:16 AM
Dec 10, 2011 07:49 AM
