64 Cutlass Axle Question
Old January 14th, 2012 | 10:15 PM
ACID64's Avatar
So I'm installing a 455 into my 64 Cutlass with a turbo 400, I'm wondering how the stock rear end will hold up. Eventually I'd like to upgrade to a cheap posi rear end, but really have no idea what to replace it with or what car it could come from. Anyone have any suggestions, or good link resources? I saw a 12 bolt posi from an el camino on Craigslist for $600, good deal, would it work well in the Cutlass?
Old January 14th, 2012 | 10:36 PM
Rickman48's Avatar
A 12-bolt from 64 - 65 Chevelle will bolt - in, with minor change in width.
Finding a cheap one, is another story, however - $800 to $1800 is normal!
Old January 17th, 2012 | 10:46 PM
monzaz's Avatar
64 rear end
Yep your car really has a small wheel well for tire and room for error.
IF you are buying aftermarket rims you can use 1968-1972 rears in the older a-body - just use an extra 1/2" to 1" negative backspacing on the rim.
You can use 1971 1972 cutlass or Buick skylark rears under the car or 12 bolt chevy
The original rear you have under the car WILL hold up to quite a bit of punishment on the street - it is the track with sticky tires and high stall or stick shift , then you will certainly start to have issues.
Best thing you can do to any rear you use is to rebearing and use aftermarket posi and gears.
we have build plenty of 8.2 BOP rears for 455 pontiac, buick and olds powered cars and they held up fine at the track(for shows etc) and street.
Take care, Jim
JD
Old January 18th, 2012 | 10:46 PM
ACID64's Avatar
Originally Posted by monzaz
Yep you car really has a small wheel well for tire and room for error.
Take care, Jim
JD
Ok, good to know. Thanks
Edzx6
May 17th, 2013 09:07 PM
Edzx6
May 13th, 2013 09:02 PM
raw442
Drivetrain/Differentials
23
April 19th, 2012 06:45 AM
cutlasssupreme71
February 22nd, 2011 12:40 PM
76Supreme350
September 16th, 2010 08:09 AM
