57 olds change to 4 3/4 bolt pattern
Old Sep 7, 2011 | 11:59 PM
bignasty442's Avatar
Question 57 olds change to 4 3/4 bolt pattern
i have a 57 oldss 88 and i was wondering if there was a way to change the front spindles to the chevy bolt pattern and any ideas with the rear end lug pattern other than rearend swap? thanks for your time!
Old Sep 8, 2011 | 08:01 AM
citcapp's Avatar
The Olds spindles do not interchange with any Chevy spindle. The same goes for the rear. If it is because of wheel choice then go to 15" wheels much larger selection to choose from
Old Sep 10, 2011 | 07:23 PM
There are lots of 5 x 5" wheels available. If you're doing this because you already have a set of wheels that you want to make fit, it will be a LOT cheaper to sell these and get the correct wheels.
defiant1
Jul 30, 2014 05:14 AM
2blu442
Apr 3, 2011 03:57 PM
mr 88 98
Dec 8, 2010 10:16 PM
Nailhead 88
Nov 19, 2008 08:21 AM
2 door cut
May 20, 2007 11:34 AM
