1980 Custom Cruiser rear axle dimensions
Old Sep 14, 2024 | 07:12 PM
olds1966's Avatar
Hi,
I have and 1980 olds custom cruiser with the 10/12 bolt. It looks like new gears are not an option. I have been trying to get a Ford 9-inch bult but can't find anyone with the specs for the build. I have some rough measurements, but I don't trust them enough for a build. Does anyone have oem specs? I attached a picture of what I have.
Thanks,
Old Sep 15, 2024 | 07:49 AM
newmexguy's Avatar
Have seen more than one, 8 1/2 inch corporate rear - with 3.23 posi, 11 inch rear drums, and a 5 x 5 bolt circle with 1/2 - 20 studs in many years of yarding. Never bought any - due to limited market and distance from buyers. Shame, because they were low rust, no scale southwestern units. Now - get one, or convert to one with bolt in axles, and theres your perfect GM rear end.
Old Sep 15, 2024 | 11:33 AM
I have an 8.5" anti-spin out of a 1984 Custom Cruiser that I can bring to Carlisle if anyone is interested.
Old Sep 15, 2024 | 04:54 PM
monzaz's Avatar
1990 -1996 Wagons will fit also. 30 spline axles,
Jim
Old Sep 18, 2024 | 02:47 PM
olds1966's Avatar
Thank you everyone for the information.
I wish I was closer to Carlisle. What is the gear ratio? I think I am over 13 hours away.
Does anyone know who might be able to build a bolt in Ford 9 inch for this application?
Mark,
Old Sep 19, 2024 | 07:41 AM
newmexguy's Avatar
Currie, Moser, and Strange are the ones recalled. Unsure how active any of them are nowadays. Moser had 78-88 A / G body units ready to go, on the shelf, back in the day. Had one in a '78 Malibu project that used to own. Suspect B / C body offerings would have to be custom built, and pre-paid.
Old Sep 19, 2024 | 08:23 PM
monzaz's Avatar
moser has a 9" option for 1971 - 1976 impala that should fit your wagon from 1980
Jim
JD Race
Old Sep 21, 2024 | 06:12 AM
brownbomber77's Avatar
Not terribly helpful but all of the 77-96 B-Body wagons will fit under that chassis, 8.5 10 bolt, 30 spline. The sedans' spring perches are like, 2" narrower or so on the late model B Body relative to the wagons.
If you're looking for bolt-in axle shafts, 73-77 Cutlass rear ends will fit under the 77-96 chassis. I have an Impala SS axle under my '77.
Finally, yes, Quick Performance sells the B Body housing for $1,000 and the whole rear end for like $3k for "77-90" but will fit 77-96 B body.
Old Jan 30, 2025 | 06:26 PM
olds1966's Avatar
Thank you guys that was good information. I was able to purchase 1971-1976 impala rear diff, everything worked great! Many hours of research and I never put that together. You have no idea how much that helped!
Old Jan 30, 2025 | 07:55 PM
monzaz's Avatar
Good to here. What ends did you get?
Old Feb 1, 2025 | 10:44 AM
olds1966's Avatar
Quick performance, 3.70 with true trac. Can't believe difference than the 2.56 gears. Feels like twice the pep and can actually use overdrive now.
Old Feb 3, 2025 | 07:29 AM
monzaz's Avatar
Yep Overdrive is nice I have had it for 30+ years. I will not go back to 3 speed - You get both lowend and top end.
davidstereo
May 21, 2012 11:53 PM
Frank3
Drivetrain/Differentials
Oct 23, 2011 07:20 PM
scrappie
Jul 18, 2009 06:19 PM
Redog
Sep 13, 2007 08:57 AM
scrappie
Apr 8, 2007 06:38 PM
