1977 cutlass brougham
Old Jun 11, 2010 | 06:00 PM
Goofy's Avatar
I am restoring my 77 cutlass brougham from the ground up. I am going to play with the engine, send away to get 400 ponies out of it. Now with that HP do I have to do any thing to the trany or rear end
Old Jun 11, 2010 | 06:51 PM
olds425's Avatar
What trans does it have? If it is anything but a TH400 I would say it needs to be built to handle it. If it was me I would have even the 400 rebuilt to take the higher power. I would probably switch to a 200R4? that is built to take it and gain overdrive also. You will probably have to upgrade or swap the rear also if you plan to take real advantage of the power you are adding .
Old Jun 11, 2010 | 06:57 PM
Goofy's Avatar
trans
Where would you look to find what type of trany it is?
Old Jun 11, 2010 | 07:06 PM
There were no TH400s installed in 1977 Cutlii. Even the 403 was bolted to a TH350.
texaninla
Jan 20, 2014 11:14 PM
TOONLOVESCHERYL
Apr 7, 2011 10:38 AM
Goofy
Jun 11, 2010 05:57 PM
Ne_stang
Sep 21, 2009 12:00 PM
Ne_stang
May 7, 2009 03:08 AM
