1976 rend end changing to eaton posi
Old Dec 10, 2013 | 05:58 PM
76olds's Avatar
Hookers under Hood
Hoping ( monzaz ) JIM can hook me up !!! 1976 oldsmobile cutass supreme ready to pick it up a bit .
Old Dec 11, 2013 | 10:10 AM
507OLDS's Avatar
Are you just installing a posi unit,or are you doing a gear swap as well? Your car has an 8.5" 10-bolt,with 28-spline axles.There are plenty of parts available for that rear.
Old Dec 11, 2013 | 10:28 AM
76olds's Avatar
Hookers under Hood
Hey Brian yes I'm changing to 3:42 . Eaton posi unti, gears , install kit , bearing and seal kit, clips . Jim on the site has given me some prices and just waiting on the costs associated with shipping it up to Canada.
Old Dec 11, 2013 | 08:22 PM
76olds's Avatar
Hookers under Hood
An update !! my car is in storage and I really have no idea if my rear is bolt in or c / clip . Cant get out to it till spring anyone have any idea what I may have in this 1976 olds cutlass supreme the missing link in getting parts . I may be SOL till spring.
Old Dec 12, 2013 | 04:03 AM
monzaz's Avatar
Axle bearings
you really do not need to buy the axle bearings at this time and most part stores will have them also. If the car is in store just wait till you can get under the car down the road or till it gets back to your possession in the spring. They are light and will not take long to get there. Jim
Old Dec 30, 2013 | 02:05 PM
76olds's Avatar
Hookers under Hood
Posi and rear gears, etc , just arrived today. Thanks Jim ( Monzaz )
All the best in the new year.
Eric
Old Dec 30, 2013 | 03:51 PM
Same gears I put in my 72! From PL #4, your axles should be bolt in.
Are you doing the install yourself or having a shop do it?
Old Dec 30, 2013 | 04:16 PM
76olds's Avatar
Hookers under Hood
I have a mag base with an interapid indicator so I'm going to give it a shot, My buddy Wayne Robinson owns "Brakes Plus" here in Orangeville. So I have good back up and a hoist.
Old Dec 30, 2013 | 04:33 PM
monzaz's Avatar
Help
Just remember to take your time and do not try to get it all done in one day. GET that pattern right and the backlash in the correct zone. Carrier preload and pinion preload. Take your old bearing and hone it out for set up ease of changing the shim try the original shim or a .038 to start.
Jim
JD
Old Jan 6, 2014 | 04:08 PM
How do you do this? I would like to make a set-up bearing.
Old Jan 6, 2014 | 05:17 PM
76olds's Avatar
Hookers under Hood
[QUOTE=Fun71;637596]How do you do this? I would like to make a set-up bearing.[/QUOTE
I have no idea I figure I will just wrap some emery cloth on a shaft and use drill to lap mine out a bit. I'm thinking -.001 or 2 thou just a slide fit. Put the shaft back in with the old bearings and use a feeler gauge to check what thickness of shim will be needed. Depending on how hard the bearing is as to what grit of paper I guess.
Old Jan 13, 2014 | 04:05 PM
76olds's Avatar
Hookers under Hood
Picked up the diff cover today just some added strength to keep my rear safe from harm. Thanks again Jim
monzaz
Nov 22, 2020 01:48 AM
csouth
Jan 17, 2013 11:21 AM
yankees
Drivetrain/Differentials
Nov 2, 2011 11:37 PM
monzaz
Apr 24, 2011 06:12 PM
oldzy
Sep 7, 2010 05:14 AM
