1972 12 bolt
Old May 8th, 2016 | 12:42 PM
deadeyejedi's Avatar
1972 12 bolt
can anyone give me any info on this rear end on my 1972 cutlass by looking at the pic ?is this an o type.it is a 12 bolt and to me looks like minimal wear .my brother in law says he can build me a posi using my existindg setup .thanks
Old May 8th, 2016 | 01:22 PM
csouth's Avatar
Count the ring bolts. If it is 10 bolt ring and 12 bolt cover its a type O.
Old May 8th, 2016 | 02:13 PM
1970 was the last year for the Type O axle, and 1969 was the last year for the Chevy 12 bolt in a Cutlass (for Canadian-built cars). The only factory-installed axle in a 1972 Cutlass would have been a corporate 8.5" ten bolt. The Olds versions used bolted-in axle shafts, not C-clips.
Old May 8th, 2016 | 02:58 PM
csouth's Avatar
I know that, but that's assuming someone didn't swap in an Olds type "O" like someone did in my '72..... Would have saved me a lot of money if the 8.5" was there as originally built.
Old May 8th, 2016 | 03:30 PM
ok got it. so regardless of the number of bolts on the differential cover ,the ring would only have ten bolts (assuming the rear is original).and would also be c-clip style.
Old May 8th, 2016 | 04:08 PM
csouth's Avatar
If its 12 bolt cover\10 bolt ring and bolt in axles, it is type "0" Olds axle. The Chevy axle will have 12 bolt cover and ring with c-clip axles. If you're lucky, its a Chevy.
Old May 8th, 2016 | 05:02 PM
My post was for the benefit of the OP - who apparently didn't really read it.
...the ring would only have ten bolts (assuming the rear is original).and would also be c-clip style.
From above:
Old May 8th, 2016 | 05:13 PM
csouth's Avatar
From above:
Gotcha
Old May 8th, 2016 | 05:19 PM
yeah i read it just to quickly i get now thanks
Old May 9th, 2016 | 05:22 AM
monzaz's Avatar
12 bolt Olds
Caps are a dead give aWAY. !2 bolt cover 10 bolt ring and those caps are all pointing to 12 bolt olds with Bolt in axles. 28 spline axles as all 31 spline axled 12 bolt olds rears were posi. (w30 cars 672 carrier)
Also you will have U bolts to hold the u-joint in where as the 10 bolt 8.5 will have 4 bolts and 2 straps.
Jim
J D
Old May 9th, 2016 | 01:09 PM
Jim,
I have an O-Type that doesn't fit that scenario:
TL code, 3.42 gears, 359 casting number open diff, and 31 spline axle shafts.
Old May 10th, 2016 | 06:56 PM
monzaz's Avatar
31 spline open
Jim,
That would be a first here. Jim
I wiill update my records with the 359 casting being the open 31 spline 4 series carrier.
Old May 10th, 2016 | 07:22 PM
although im 99per cent sure this is the original rear end ill assume nothing . ill take it apart to be sure its 28 spline 10 bolt ring gear i would like to change the gears as well .any recomendations on where to buy the gears and carrier all in one package ?
Old May 12th, 2016 | 06:52 AM
csouth's Avatar
If its a type O in a 72, it is not original. Should be 8.5 10 bolt. Monzaz would be able to help you with options for that rear.
Old May 12th, 2016 | 07:54 AM
oldsmobiledave's Avatar
99% you say
You are 99% sure but 100% wrong. Type O was discontinued after 1970.
Jim at JD Race aka Monzaz can sell you everything you need.
Old May 12th, 2016 | 08:51 AM
I never said it was an o type .I asked if it could be identified by the pic .
Old May 12th, 2016 | 12:08 PM
Yep, and monzaz confirmed it was an O-Type so it is not original to your car.
Old May 12th, 2016 | 01:30 PM
csouth's Avatar
Just contact Jim(monzaz). He's well versed in retrofitting posi's and newer gear's into these type O housings. I was talking to him years ago about doing mine, but I pulled it for a 9" which better suited my intentions for the car.
jdrace.com
tmcfall
May 29th, 2024 12:41 PM
tru-blue 442
Drivetrain/Differentials
May 7th, 2012 08:48 AM
72442conv
March 19th, 2012 07:14 AM
olds4life
October 5th, 2010 05:18 AM
dman0712
March 16th, 2010 07:40 PM
Quick Reply: 1972 12 bolt
