1962 F-85 Drive Shaft
Old Sep 9, 2009 | 02:46 PM
instructionset's Avatar
Hi all,
Upon the recommendation of someone on this board, I posted an ad on 442.com for a slip yoke ball seat for my F-85 a few weeks ago. I haven't had much luck, but I did receive about 7 emails from different people all from the same address in London. Needless to say, I think something might be scammy about that.
Anyways, i have had the shaft out of this car for nearly a year. It is totally undriveable in its current state. My drive shaft guy has the shaft, an can re-tube it, but neither him, nor I can find the parts for the slip yoke CV/U-joint thingy.
Anyone have any recommendations?
Much Thanks,
Bill
Old Sep 9, 2009 | 04:35 PM
citcapp's Avatar
I wonder if they used the same center support and bearing system from 57 all the way up to 64. I have a 57 unit and can't find enough information to confirm if it is the same. Does anyone know?
Old Sep 9, 2009 | 10:00 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
64 was the last year for those I believe. They came on all the X frame cars. Had 1 in a 64' Lesabre.
Old Sep 9, 2009 | 10:44 PM
As far as I know, the shaft setup on my car was only used on the 61-63 F-85's. Might have also been used on the same period Buick Specials, but I don't know for sure.
Maybe the '64 did use the same pieces. If it did, it will let me widen my parts search a bit. I'm still not too optimistic. I figured I would have found something by now. Hell, Jay Leno can get parts for much weirder cars.
I asked my drive shaft guy about maybe replacing the whole CV head with a similar but non-identical modern unit but he didn't seem to like the idea much. I'm not worried about the drive shaft being original, although I'm trying to keep it as original as possible. Anyone think this might work?
-Bill
Old Sep 10, 2009 | 10:04 AM
citcapp's Avatar
http://www.rockauto.com/ has parts listed for the CV joint under 1962 F-85 for $19 check them out it. If you need more information give them a call they are very helpful
Old Sep 11, 2009 | 09:41 AM
Well I found those U-joints at rockauto, but unfortunately it seems they don't have the rest of the parts for the joint.
Old Sep 11, 2009 | 03:02 PM
citcapp's Avatar
Do you have pictures on the bad parts so I can compare to the 57 parts I have to see if they are the same?
Old Jan 10, 2013 | 12:29 PM
beachmont's Avatar
Originally Posted by instructionset
Hi all,
Much Thanks,
Bill
Did you ever find anything on this? I've been looking for the rubber bushing that goes over the center bearing in the drive shaft for months now. Any help would be appreciated.
Al
Old Jan 12, 2013 | 05:24 AM
monzaz's Avatar
pictures
I think pictures would help alot of people help you. Jim
Old Jan 12, 2013 | 11:18 AM
jensenracing77's Avatar
there is a guy on the jetfire forum that could help. Would you happen to be a member there? All 61-63 F 85, Cutlass and Jetfire info there. Not real active there but someone will likely be able to help.
Old Jan 13, 2013 | 03:14 PM
beachmont's Avatar
I am not a member over there, but I'll take a look. Here are the parts I am talking about:
Old Jan 14, 2013 | 07:24 PM
monzaz's Avatar
PArts
I think there is a 1963 in a yard here - I will try to get there and check it out. So that is the center carrier bearing for the drive shaft correct? Jim
Old Jan 15, 2013 | 02:38 PM
beachmont's Avatar
Hi Jim,
It is the center carrier bearing. I got a brand new bearing from Rock Auto but I'm looking for that rubber bushing that goes around it. My bushing is in rough shape. If you have it I'm interested.
Thanks,
Al
Old Nov 21, 2013 | 08:22 AM
1k442's Avatar
Center support.
http://www.oldbuickparts.com/catalog...al-p-2948.html
Driveshaft Support 1962-63 Buick Special
[BS623-3] $48.75
1962-1963 Buick Special, Skylark
Propeller (Drive) Shaft Center Bearing Support
New manufacture
Be sure to replace the bearing too!!
Good luck,
Ken
Frogge467
Mar 24, 2012 11:09 PM
egknz
Drivetrain/Differentials
May 15, 2011 07:30 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
rose
Feb 24, 2009 10:42 AM
68conv455
Apr 11, 2008 11:48 PM
