1961 and 1963 Full Size Rear End
Old Oct 18, 2011 | 07:33 AM
KQQLCAT's Avatar
What is the difference between a rear end in a 63 Starfire and a 61 88?
I have a line on a 63 Starfire Posi rear and would like to use the whole rear assy.
Pat
Old Oct 18, 2011 | 09:04 AM
copper128's Avatar
Lt. Buzzkill (ret.)
I don't think there's any difference. Should be a bolt-in if the pinion flange is the same.
Old Oct 18, 2011 | 09:18 AM
rocketraider's Avatar
Oldsdruid
I believe all 57-64 Olds and Pontiac rears are the same. Maybe a slight difference in track width on 59-later Pontiac, but 61 and 63 Olds should be identical.
Hm. OD with a 3.42 posi should make for an interesting ride! Can't remember which trans you put in there, Pat.
Old Oct 18, 2011 | 11:19 AM
chequenman's Avatar
If you're talking '57-'60 and changing the whole housing (Banjo Housing) those vehicles had Leaf Spring suspension and there would be a lot of work at converting.
Rear End change out of the Pumpkin is easy, but a lot of the Pontiac Diff's (Pumpkins) have finer spline Carriers!!!
seymog
May 7, 2022 08:20 PM
350TurBRO
Sep 12, 2014 11:52 AM
trackz man
Mar 4, 2013 10:42 AM
Delmont 88 425
Oct 2, 2010 08:52 AM
Natas
Drivetrain/Differentials
Oct 15, 2007 11:41 AM
