1955 pinion seal/carrier issues
Old Jan 12, 2012 | 09:28 PM
oldsmobum's Avatar
So I had my rear end rebuilt about a year ago, with all new bearings and seals. Since then I have maybe driven 3,000 miles. Within about the last 1,000 miles I noticed the pinion seal is leaking, and leaking somewhat badly.
I initially had the rear rebuilt because the carrier bearing was shot and made a hell of a noise when coasting. This noise is starting to redevelop already.
Is this something the shop I took it to screwed up? To be fair the hydramatic in that thing under certain circumstances shifts VERY hard and the trans stays in gear while decelerating, and slows the car down. Would this damage the rear end in any way? Any help is appreciated. I will be calling the shop I took it to regardless, I'm just curious how disappointed I should be.
Old Jan 12, 2012 | 09:57 PM
Rickman48's Avatar
Let us know what the shop says, as there's no other reason than poor installation, unless you've a cracked housing!
Old Jan 17, 2012 | 09:50 PM
monzaz's Avatar
rear issues
Well if they did not change the race there could be your problem again...BOTH need to be new...if one is bad the other is too. thery could have just done the outer bearing and not the inner...
The pinion nut could be backing off - HAppens ALOT - New nut should be used with lock tight and we even peen the nut to the thread to prevent this...
SO- many things to check- tell them you want the old parts back when replaced. That helps. Jim
sbFALL63
Mar 23, 2011 02:23 PM
oldzy
Drivetrain/Differentials
Dec 22, 2010 07:14 AM
1973olds98
Aug 17, 2010 11:48 AM
drewt
Dec 1, 2009 07:28 AM
jensenracing77
Apr 16, 2009 04:59 AM
