12 vs 10 bolt
Old Nov 17, 2009 | 10:14 AM
ozbie's Avatar
12 vs 10 bolt
On my '72 Cutlass project I have a Olds 12 bolt rearend and I just aquired a 10 bolt off of a '72 Cutlass 442 (350)...both rearends are non-posi...are there any real differences between these combinations?
Old Nov 17, 2009 | 10:19 AM
ozbie's Avatar
I found my answer in a previous post...forgot to search first.
...I guess I'll use the rearend that looks cleaner.
Old Nov 17, 2009 | 01:13 PM
kaz442's Avatar
Use the 10 bolt out of the '72. Its an 8.5' and posi carriers and parts are plentyful for them. The 12 bolt olds rear is very limited on posi parts and not as strong. JKaz
Old Nov 17, 2009 | 02:17 PM
While I agree about the limited parts availability, why do you say that the Type O is not as strong as the corporate 8.5"? Both have an 8.5" ring gear held on with ten bolts. Both have the same 1.626" pinon shaft. The only difference is the Type O has 27 splines on the pinion and the corporate has 30.
Old Nov 17, 2009 | 05:53 PM
monzaz's Avatar
you nailed it
There you go...you answer you own question....
The yoke also is much beefier on the corp 8.5 too.
there is more support around the u-joint cap compared to the u-bolt set-up on the olds 12 bolt (which basically is a pontiac 8.2 yoke)
All in all for the street flip a coin. Jim
You can however up grade the 8.5 to 30 spline a lot easier than you can up grade the strength on the 12 bolt 'o' rear too.
tmcfall
May 29, 2024 12:41 PM
tru-blue 442
Drivetrain/Differentials
May 7, 2012 08:48 AM
72442conv
Mar 19, 2012 07:14 AM
olds4life
Oct 5, 2010 05:18 AM
dman0712
Mar 16, 2010 07:40 PM
