96(I know!) Cutlass Ciera TCC
Old Oct 1, 2011 | 10:22 PM
yzzerdd's Avatar
Hello,
Used to be active on the forum when I owned an '83 Olds Custom Cruiser. Well I'm back in an Olds (finally), but it's a newer one. Anyhow, I'm hoping someone here might be able to help.
I've got a 96 Cutlass Ciera with a 3.1 V6 and a 4-speed automatic OD trans. I ran the codes, and it's pulling that there is a problem with the TCC....So, that translates to a problem with the solenoid, or a problem with the wiring. It engages hard into second, seeming as if it is shifting too hard. If I get up off a light somewhat fast, and slightly let off the gas between 1st and 2nd, I can get the car to shift great. Or if I start off slow (hardly on the gas anyhow), it shifts great.
Can anyone tell me their experience with this issue? I've had the car for a few thousand miles, and it just started this 500 miles ago. Is the solenoid internal or external? Is this common? Could a trans flush free up the solenoid?
--Jack
Old Oct 2, 2011 | 07:13 PM
nofiveo's Avatar
the solenoid is inside the side cover of the trans. what is the exact code it's giving you? I't'll help with diagnosing the problem.
gbodyguru
33
Aug 25, 2015 06:23 PM
siropchik
May 23, 2013 05:42 PM
bermuda
May 18, 2006 11:38 AM
Big Dave
Dec 15, 2005 12:02 PM
