bolt missing on rear hub assembly
Old Aug 25, 2011 | 10:33 PM
nj_cutlass72's Avatar
so when I bought the car, I noticed that one of the lug nuts was missing and this bothered me.
I figured I'll take of this, so it's the rear wheel on passenger side and I took the wheel off to have a look.
Two questions, to mount a new bolt do I have to take off everything behind it for clearance? or is it a easy slip in, one friend mentioned that I have to bang it in with a hammer. Please see pics, also does a local store have this or I need to go online? thanks in advance...
Old Aug 25, 2011 | 10:45 PM
Run to Rund's Avatar
If the axle hole is undamaged and a new stud doesn't just fall into place, you can use a lug nut and grease the threads to pull the stud into place. If the hole is just a bit iffy, use some Loctite. If the stud falls into place, you need a stud with larger diameter splined area that will fit tight. Parts houses carry the studs.
Old Aug 25, 2011 | 11:36 PM
thanks, will give it a try and let you know.
Old Aug 26, 2011 | 04:12 AM
69442C's Avatar
Obtain the correct stud, install the stud from the back side, place a washer and a lug nut (installed backwards so flat end is against the washer) and tighten it until the stud is fully seated. If you have an impact wrench, that will make the install go very quickly. I would not use any grease on the splines. If the hole in the axle is damaged, you'll need to get another axle.
Old Aug 27, 2011 | 08:21 PM
using washers to pull the stud to flush was a great idea, all done - thx
marxjunk
Feb 24, 2015 06:45 PM
CUT-N-UP
Nov 6, 2013 07:10 PM
bulldog
Sep 27, 2010 05:03 AM
oldsonharmont
Suspension & Handling
Dec 23, 2009 10:59 PM
elcaminodave
May 26, 2009 02:49 PM
